spec your turboTurbo F22B Info
Old Jan 24, 2003 | 01:43 PM
poid's Avatar
Default spec your turboTurbo F22B Info
Since i had no response in the FI forum i thought i'd try here.
I'm looking for info about turbo F22B setups. Mainly what spec turbo you are using and roughly what RPM you hit boost. Also if you have power figures/quarter mile times that would be good as well.
Cheers guys
Old Jan 24, 2003 | 02:12 PM
niedejb's Avatar
Default Re: spec your turboTurbo F22B Info (poid)
t3/t4b .48 A/R (.57trim I think whatever Fmax ships) @ 13psi
Old Jan 24, 2003 | 02:13 PM
brucelee (The original)'s Avatar
Default Re: spec your turboTurbo F22B Info (niedejb)
Thats a really nice dyno sheet. Impresive.
Old Jan 24, 2003 | 02:16 PM
niedejb's Avatar
Default Re: spec your turboTurbo F22B Info (brucelee (The original))
Thanks...theres more to come though.
Trying to prove F series potential.
poid's Avatar
Yeh thats very impressive. I am guessing you've done some internal work to be running 13 psi?
Old Jan 24, 2003 | 02:19 PM
niedejb's Avatar
Stock internals.
I'll let you know what forged internals and sleeves will yeild. (Search for been busy post).
Old Jan 24, 2003 | 02:29 PM
.Noah Fecks's Avatar
so i wanna know what else you have done to that thing to be putting down 250 to the wheels. thats very nice. i maybe have to get a f22 and build the **** out of it for the same price as a stock h22.
Old Jan 24, 2003 | 03:21 PM
twkdCD595's Avatar
Default Re: spec your turboTurbo F22B Info (EVIL Wagon Wheels)
what a/f ratio are you at in that dyno pull niedejb, just curious... thanx.
Old Jan 24, 2003 | 03:24 PM
twkdCD595's Avatar
I believe he uses a pretty much the fmax kit minus additional injector **** with a set of 440-450cc injectors/ vafc hack?... from what I gather.
Old Jan 24, 2003 | 04:35 PM
poid's Avatar
stocks internals?
Crap that is very, very impressive. Am i understanding the dyno graph right in that you are hitting boost at around 2700rpm?
EDIT: how long have you run this setup for? Have you had any problems with it??
[Modified by poid, 11:40 AM 1/25/2003]
Old Jan 24, 2003 | 05:30 PM
ArchAngel Sabastian's Avatar
New User
he hit boost more about 3100-3500 ish i think, stock internals
aem cam gear, aem power pulley, stock crank pulley,
fuel pump, RC injectors, crane ignition, vafc. 2.5 exhaust/cat
im pretty sure he had no probs, check his site in his sigy it tell you eveRyting
[Modified by ArchAngel Sabastian, 8:32 PM 1/24/2003]
Old Jan 24, 2003 | 06:27 PM
98AccordEX's Avatar
Default Re: spec your turboTurbo F22B Info (ArchAngel Sabastian)
why do the RPMs only read to 5200?
Old Jan 24, 2003 | 06:40 PM
Default Re: spec your turboTurbo F22B Info (98AccordEX)
yeah an theres no power and the dyno starts at 2800
Old Jan 25, 2003 | 08:23 AM
niedejb's Avatar
Default Re: spec your turboTurbo F22B Info (twkdCD595)
Heres the raw number dumped into excel so you can see the a/f curve.
This is the first and last run at 13 psi. We dialed all the fuel (vafc, 4:1 fmu, 500cc injectors..NO HACK) for 10 psi so we werent about to change all the settings for this setting. Its on the lean side, but I was tuning for 10 psi not 13.
Old Jan 25, 2003 | 08:24 AM
niedejb's Avatar
The dyno owner was having trouble picking up a good ignition signal all day. When the ignition drops out you get no graphing.
Had several runs like this.
Old Jan 25, 2003 | 08:26 AM
niedejb's Avatar
Dyno runs start whenever the operator presses the button. Thats just where he happen to hit it.
Old Jan 25, 2003 | 08:54 AM
GZERO's Avatar
dyno's doesn't measure under 2000RPM
Old Jan 25, 2003 | 09:00 AM
98AccordEX's Avatar
Default Re: spec your turboTurbo F22B Info (GZERO)
my dyno charts start around 1700. not like its a big deal though. dynos on 4cyl Hondas dont matter until about 3000
Old Jan 25, 2003 | 09:06 AM
Jin Yamato's Avatar
Nice torque!!!!
Old Jan 26, 2003 | 03:14 PM
poid's Avatar
Default Re: spec your turboTurbo F22B Info (jin_)
Just wondering does anyone have a similar turbo to neidjb but with a .63 AR instead? How would that compare, in particular regarding the point at which it'll boost
Old Jan 26, 2003 | 04:07 PM
New User
my setup will be similar to his im using a
T3/T04E, 57 trim like the FMAX turbo but
.48a/r comp
.60a/r turb
im debating a 50trim 60-63 a/r
[Modified by ArchAngel Sabastian, 7:15 PM 1/26/2003]
Old Jan 26, 2003 | 04:09 PM
niedejb's Avatar
.48a/r comp
.60a/r turb
Good choice. I think the turbo will be my limiting factor with the sleeved engine.
May have to go the same route later on.
Old Jan 26, 2003 | 04:16 PM
New User
Thanks man...
Old Jan 27, 2003 | 01:27 AM
poid's Avatar
Out of curiosity, how has the turbo setup affected your fuel economy. Not that i care about economy, just interested
Old Jan 27, 2003 | 02:16 AM
niedejb's Avatar
The turbo hasnt affected my economy, but the way I drive has.
Still get 22mpg or more.
