to those with the JDM front end- !
Old Jan 24, 2003 | 10:14 AM
zRd#1's Avatar
Default to those with the JDM front end- !
Modified by zRd#1 at 1:14 AM 3/1/2005
Old Jan 24, 2003 | 10:17 AM
zer0zer0 TypeR's Avatar
Default Re: to those with the JDM front end- ! (zRd#1)
the latch is fine, the cable on the 94+ is too short. just go to acura and buy one, it's not that expensive...
Old Jan 24, 2003 | 11:31 AM
B2FiNiTY's Avatar
You need a longer latch cable.
Old Jan 24, 2003 | 11:50 AM
PYMUGENITR's Avatar
Default Re: to those with the JDM front end- ! (B2FiNiTY)
go to honda and get a mid 90's 2 door accord cable, it works perfect!
Old Jan 24, 2003 | 11:52 AM
(__________)'s Avatar
Default Re: to those with the JDM front end- ! (PYMUGENITR)
so you can use your stock latch you just need a G2 teg latch cable? Anyone know the part number for that?
Old Jan 24, 2003 | 11:54 AM
B2FiNiTY's Avatar
Default Re: to those with the JDM front end- ! (steves98itr247)
I believe you have to flip your stock latch upside down.
Old Jan 24, 2003 | 12:01 PM
not upside down, just flip it from left to right
Old Jan 24, 2003 | 12:19 PM
Default Re: to those with the JDM front end- ! (zer0zer0 TypeR)
Did any of you install the conversion yourself? Im bout to do mine here in earle Feb.
Old Jan 24, 2003 | 01:47 PM
98ITR#0020's Avatar
I did it.. just flip the latch around and then go to the junkyard and take the cable out of it. Its reasl easy.
Old Jan 24, 2003 | 02:27 PM
QuestRacing-TypeR's Avatar
Default Re: to those with the JDM front end- ! (98ITR#0020)
was just wonder if i can use the stock hood latch on my 2001 itr and then use the 91 integra cable relese. i getting it done right now
Old Jan 24, 2003 | 02:28 PM
Default Re: to those with the JDM front end- ! (QuestRacing-TypeR)
YES the latch is FINE. just tell the shop or whoever to flip the latch around. the cable is too short, go buy the 90-93 cable.
Garrett
Oct 28, 2016 10:05 AM
jdmjackson
Jun 24, 2013 03:20 AM
bigislandc2
Jan 21, 2007 07:32 PM
redline32
May 30, 2004 02:46 PM
Type Smoothe R
Nov 7, 2003 06:09 PM
