will 92-95 civic coilovers fit our cars?
Old Jan 24, 2003 | 08:51 AM
model x's Avatar
Default will 92-95 civic coilovers fit our cars?
I know one person on HT is using an EK set of coilovers on his car with minimal mods to make it fit.
Would it be the same for the 92-95 civics?
Does anyone have the length of an 88-91 civic/crx front and rear shock/strut assembly?
Old Jan 24, 2003 | 08:53 AM
d15dood's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (model x)
im using struts and coilovers off a 94 civic ex on my 89 hf. everything fit perfectly. im pretty sure its all the same from 88-2000 civics.
Old Jan 24, 2003 | 09:07 AM
theclutchpoppa's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (jungle)
ha yes me too i was wonderin if the 92-95 was ok to use on my 88 si
Old Jan 24, 2003 | 09:46 AM
SlammedHatch90's Avatar
when i ordered coilovers for my 93 ex they said they would fit 88-00 civic's so im positive they will work
Old Jan 24, 2003 | 09:53 AM
McD's Avatar
McD
Default Re: will 92-95 civic coilovers fit our cars? (1SexyJDMGirl)
oh yeah, they'll work
Old Jan 24, 2003 | 10:04 AM
primoEF's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (McD)
yes but you will need EG front forks
Old Jan 24, 2003 | 10:16 AM
model x's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (EFDog)
I just wanna be clear when I say coilovers I mean full coilovers, not just sleeves.
That's awsome. Does anyone know the difference in length between the 92-95 and 88-91? Will we gain or lose travel by using the 92-95 stuff?
Old Jan 24, 2003 | 12:29 PM
Radex's Avatar
They will fit with Civic 92-95 or ITR drop forks. Although I must say my Koni's made my car a bit too high. Solution for front is to lower the shocks in the drop forks. Rear ones are worse, I'm thinking about custom upper mounts. Of course I can go low but on a lowest perch seat that means too soft. This is with Koni, maybe other brands with shortened shock bodies will work just fine.
Old Jan 24, 2003 | 12:32 PM
Steve91's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (Radex)
Ground Control now makes upper shock mounts that give you 3/4" more shock travel. It physically mounts the shock a bit higher than the factory mount. I have a set in the front and they work great. They go for $75 a pair.
Old Jan 24, 2003 | 12:45 PM
palmeref9's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (Steve91)
someone find out if the full coilovers work i like to use a tien flex system on my 91 std but they won,t make them but they have them for 92-95 civic
Old Jan 24, 2003 | 05:17 PM
Drumwurks's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (palmeref9)
I always thought the 92+ coils were longer than those of the 88-91...
Something like just the fronts were taller?
Anyone know about that?
Old Jan 25, 2003 | 08:44 AM
Radex's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (Drumwurks)
Yes, they are taller (Koni's at least). This is why a car is too high.
Old Jan 25, 2003 | 05:59 PM
Drumwurks's Avatar
Thanks Radex.
Old Jan 25, 2003 | 06:07 PM
slowpokesi's Avatar
yes they will fit,
the shocks are approximately 1/2 inch higher
and the forks might be a tiny bit longer
Old Jan 25, 2003 | 06:14 PM
shorti's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (slowpokesi)
good god i asked this same question before and noone answered....wtf
i know now that eg+ oem or aftermarket shocks & struts WON'T fit on 88-91 because they are too long....
88-91 oem or aftermarket shocks & struts WILL fit on eg+....it will just make the car a little lower....
any coilovers (eg+) will fit 88-91 because they are ajustible....
feel free to proove me wrong
Old Jan 25, 2003 | 08:27 PM
model x's Avatar
This is my exact plan! And I know someone else on here is using EK full coilovers on their EF.
Old Jan 25, 2003 | 08:56 PM
714phil's Avatar
i have Tein HAs made for EGs. 1. you will need eg,ek front forks. i also used the the 88 rear control arms. they are pretty tall compared to coilovers made for 88-91 civic/crx's. im about 5-6 threads away from the bottom thread, but to answer your question.. Yes they will fit. Hope that helps.
Old Jan 26, 2003 | 12:21 AM
Ham'ed Hatch
Guest
Posts: n/a
honda never put "drop forks" in it's suspensions.
although they did use damper forks...
Old Jan 27, 2003 | 08:25 AM
slowpokesi's Avatar
Default Re: will 92-95 civic coilovers fit our cars? (shorti)
they will fit because im running them right now,
what do i win.
Old Jan 27, 2003 | 04:11 PM
model x's Avatar
So what exactly are you using?
Do you have any pics?
Do you find you have enough travel?
If you answer all these I'll send you a cookie
what do i win.
The Collin
Jan 18, 2007 06:56 PM
allnapower
Jan 11, 2007 09:49 PM
ShakesTheKlown
Jun 4, 2003 08:49 PM
dingusjt
10
Oct 28, 2002 10:49 AM
Gonzo
Feb 7, 2002 01:40 PM
