sensors on greddy kit
on the greddy sohc kit, there is no place to put the stock air sensor. does anyone know where they go or if they are removed. help. need to put in kit by the weekend.
Stock air sensor??? By this I take it you mean that you have a 96-00 Civic EX that has the IAT (Intake Air Temperature) sensor plugged into the intake tube rather then the back of the intake manifold like the 92-95 cars do. So with that said, since the Greddy kit you're trying to use was made for the 92-95 cars you can't install that kit on your car. J/K
Just drill a hole into the intake pipe on the Greddy kit where the sensor needs to plug in. Get a nice little rubber grommet for the hole you drilled and plug the sensor into it like it was on your stock rubber pipe and PRESTO!
Enjoy!
Just drill a hole into the intake pipe on the Greddy kit where the sensor needs to plug in. Get a nice little rubber grommet for the hole you drilled and plug the sensor into it like it was on your stock rubber pipe and PRESTO!Enjoy!
Secret Squirrel
16
Jul 13, 2003 08:35 PM
turbod16y7vtec
Nov 18, 2002 05:18 AM
