Just got my greddy kit.. doesn't have a place for AIT sensor.. should i make one?
should i drill a hole for the AIT sensor.. because on the obd2 cars its in the intake so i woundering if i needed to do that..?
Re: Just got my greddy kit.. doesn't have a place for AIT sensor.. should i make one? (d16y7vtec)
I am not sure..but someone told me..u could leave those alone...and you'll be fine...as long as u have piggy back ecu or standalone...not sure..but that's what I heard
jjust drill a hole thats what i did, make sure you drill it kinda small so it doesnt pop out under boost...
Re: Just got my greddy kit.. doesn't have a place for AIT sensor.. should i make one? (CzanSOHC)
what is that for anyways? cause i just left it hanging there
Guest
Posts: n/a
i drilled a hole, then used a 3/8th inch grommet to secure it tight in the intake tube for the turbo. Youll prolly get a leak anywhere in the charge pipes.
Re: Just got my greddy kit.. doesn't have a place for AIT sensor.. should i make one? (PeloTudo)
Air Intake Temperature sensor. It won't do anything to leave it just zip tied to the back of the engine. If your really worried about it, drill a hole in he intake pipe on your turbo. Make sure you put it BEFORE the turbo cause it could blow out under boost. I found that out the hard way. Nothing like boosting 10 psi the first time and hearing a loud *** POP, and not knowing what it was.
Nick
Nick
Re: Just got my greddy kit.. doesn't have a place for AIT sensor.. should i make one? (T25 civic)
well currently i did zip tie it to something and its just hanging there so i was just making sure that it wasn't hurting anything thanks guys..
