aftermarket axles or no?
i was thinking about going with a set of aftermarket axles (prodrive, dss, etc.) but, when doing so, if the axles don't give, would something else in the drivetrain give? such as the transmission or differential?
i have a quaife and i'm not sure if it could hang with a set of aftermarket axles but, this is a large concern because this is a daily driver and i figure, if maybe 3 sets of axles are broken, i would have almost shelled out the same amount for a set of aftermarket axles
ls turbo with a built and sleeved block, quaife, ls tranny, m&h 24.5 x 8.5 slicks
What are your time's and 60ft.?
putting 330 hp down and 263 lbs of torque.
Dude, you got a Quaife, it won't break. And if it does you can send t back and it will get replaced for free!!!! Get some axles and you'll be alright... Hope this helps.
Later,
Sean C.
Later,
Sean C.
shouldn't be a problem. I haven't heard of tranny problems except the Synchros going crazy on you. But thats about it man.
[Modified by MnC CRX, 10:05 PM 1/29/2003]
so are you guys saying that an LSD is definitely needed if someone goes with a stronger axle combo?
