b16a2(sirII).....94 civic ex (92-95 civic)
i have some questions about this swap...mainly obd differences ( i know mine is obdI...sirII is obdII right? ). So i have read to change injectors, dist., and i think ecu (chipped)...to get the b16a2 running right, i'm just making sure, is this correct? What about a obdII > obdI conversion harness, will it work as well?
ok...the rear motor mount also needs to be from a 94+ gs-r, now do most places that sell swaps sell this mount with the motor (i.e. Hmotorsonline)? Basically do they sell the swap to fit the car? or is a swap sold as is....meaning buying extra parts to get it to work...?
I think thats about it.....about half is questions and the other half confirmation....
I've already searched through 30+ pages.....Thanks in advance.
no the SiR II is OBD1 it was found in 92-95 civic hatches (the SiRII) in japan.
the b16a2 is 99+ and its obdII. the SiRII is just called a b16a.
i got my swap from steve (hondamotors) and everything came with it.
ahhhh....so an sirII is plug and play with the exception of the knock sensor wires....maaaybe vtec wire(s)?
sweet...thanks, thats what i was lookin for
is the sirII b16 a plug n play in my obdII EK?? besides the vtec wire. sorry for posting in your thread dude, i had the same question but on different year.
you are better off trying to find a REAL b16a2 and doing it that way
you need to change injectors, distributor and other various things i dont remember.
not to mention converting to obdI
no
no
odds are they are using b16a2's wich are DIFFRENT than SIR II's
you can use an SIR 2 if you convert to OBDI and im 99% sure you dont need to change the dist. and injectors then.
to kamin: how much did you spend total for the complete swap? And your saying you didn't buy anything extra JUST the complete sir II swap from hondamotors?
and no i didnt need anything extra for the swap. everything worked fine that came with it
when he says complete swap, he means, complete swap.
[Modified by Kamin, 11:46 PM 1/25/2003]
CiViCShella
Jul 10, 2012 02:04 PM
