paint job prep...
Old Jan 23, 2003 | 09:48 PM
LANEVOIX's Avatar
Default paint job prep...
i am planning on preparing my car and primering it myself to get a paint job...any tips on how to sand it down and what primer to use...i heard that some primer will react with paint and would bubble up...
Old Jan 23, 2003 | 10:07 PM
viCeVerSa's Avatar
Default Re: paint job prep... (charminpnoyracer)
umm , um im not 100% on this so dont hold me to it and other people please correct me if im wrong ......first you are going to want to sand it with a fine grit paper , then apply an etching material and a sealer and then get a primer, as for as bubbling and stuff , there ARE ddifferent kinds of paint and you should match your paint to your primer..............i could very well be mixed up its been a while since auto body class
[Modified by viCeVerSa, 7:08 AM 1/24/2003]
Old Jan 23, 2003 | 10:17 PM
LANEVOIX's Avatar
Default Re: paint job prep... (viCeVerSa)
what grit sandpaper should i use...
Old Jan 23, 2003 | 10:18 PM
Evs-One's Avatar
Solbros Owns Me
whatever base you paint your car with, use a primer with the same base. Enamel, Laquer, Urethane, etc. BTW this has been covered WAY too much and there is usefull sources in your public library and all over the net. If you are doing body work, sand down to the metal. If not, just sand through the clear coat. If no bodywork is being done, no need to go lower than 180 grit-although it will clog easily. Sand through the clear coat, then you have some options. You could either wet sand with a 600 then 1000, then apply paint, or you just spray some self etching primer, then a sealer, then your finish. You have many options and if you don't know where to start, then that's when you read a 200 page book on painting your car. There's too much to learn and you can never know enough.
Old Jan 23, 2003 | 10:21 PM
viCeVerSa's Avatar
Default Re: paint job prep... (Emerica)
yeah it all came back to me, thanks emerica
Old Jan 23, 2003 | 10:29 PM
Evs-One's Avatar
Solbros Owns Me
I pretty much just re-worded what you said...lol. There's WAY too much to say about prep. You could just degrease the car and spray and it will come out clean. You could remove every last nut, put it on a rotissery and sandblast, dip, and paint, etc and make it look good. All depends on money, time, and how you want the end product to be. READ BOOKS!! You'll learn way more than the internet.
Old Jan 23, 2003 | 10:33 PM
viCeVerSa's Avatar
yeah last semester in auto body we put back together an old 61 chevey truck looked like **** when we started , but we have a sand blaster and its comes out so nice after you blast something especially if it has a lil rust on it
Old Jan 23, 2003 | 10:38 PM
Evs-One's Avatar
Solbros Owns Me
oh, I love early 60's chevys. I have a 70 chevy I'm almost done with
Old Jan 24, 2003 | 12:35 AM
tnbigdawg's Avatar
okay dude, I'll give you some Professional pointers here:
first of all use Wax and Grease Remover before you do anything. Use a lot of it, and use a lot of clean paper towels to prevent recontamination from using the same rag.
If your car is in perfect condition( No Dents or Dings) all you have to do is wetsand your car with 500-600 grit paper. Clean and degrease your car again right before painting. Use a primer sealer Just Right before painting it with color and clear. NEVER USE SPRAY CANS!!!!
If it has dents, fix those. then primer with an EPOXY PRIMER(unless your car has been painted with laquer). Block sand the primer with 400grit(wet) or 320(dry). Clean and degrease your car again right before painting. Use a primer sealer Just Right before painting it with color and clear. NEVER USE SPRAY CANS!!!!
goodluck.
*note: if you do not know what you are talking about, then please do not post a reply to people's questions. It only misinforms them.
Old Jan 26, 2003 | 04:43 PM
LANEVOIX's Avatar
Default Re: paint job prep... (tnbigdawg)
thanks...good post
phoenix_iii
Paint and Body
10
Oct 10, 2023 11:58 PM
VegasEg8
Paint and Body
Sep 11, 2014 09:30 PM
jwicecold
Paint and Body
30
Nov 9, 2011 10:38 PM
GoLowDrew
Paint and Body
May 16, 2010 05:21 AM
toojdmforschool
Paint and Body
10
Feb 12, 2009 08:52 AM
