RC310 ...resistor box
Old Jan 23, 2003 | 07:45 PM
FitCRX's Avatar
Default RC310 ...resistor box
Asking some questions to learn somethin.
How to run 310 injectors in a b16? It has header, exhaust, manifold. Also an apexi controller. From what I have picked up...I still need a resistor box, but from what car? Please give me your thoughts and comments, please not the ones ask "WTF...why would you wanta do that..the car doesn't need it". Thanks
Old Jan 23, 2003 | 09:48 PM
TEAMGENDAI's Avatar
Default Re: RC310 ...resistor box (FitCRX)
if the injectors are low resistence you will have to use a resitor box. if it is a crx and it is a si you should already have one if not get it from any 88 91 si
Old Jan 24, 2003 | 03:13 PM
FitCRX's Avatar
Default Re: RC310 ...resistor box (TEAMGENDAI)
It is in a CRX Si. So it should work? The first time I put them in, I couldn't get the car to go over 50...I guess I will try them again, maybe I did something wrong the first time.
Is there a way to tell if they are saturated or peak and hold injectors...just buy lookin at them?
Old Jan 24, 2003 | 03:23 PM
sgT's Avatar
sgT
there is a part # engraved on them. get that and i can tell you which they are.
though i rarely see 310s that are peak hold
Old Jan 24, 2003 | 03:53 PM
FitCRX's Avatar
Default Re: RC310 ...resistor box (sgT)
while talking to you I also talked to another guy...he says this
Most RC injectors are saturated. You need peak-and-hold
injectors for the B16A1.
You can use the RC injectors, but you'll have to take the resistor
box out of the wiring harness and run individual power to each
injector. Major pain in the ***!
If you need a larger injector for that engine, I would recommend
the 92-96 Prelude injectors. They are 330cc/min and they are
peak and hold.
You can tell what type of injector you have by using an ohm
meter. Put one wire on each of the injector contacts. 2-3
ohms is peak and hold. 10 ohms or higher is saturated.
Sonny
And I think its bad news for me...couldn't find my electrical meter, but using your engraving...it says SL2-310.
I think I just learned a lesson...always know what your getting before you order! I asked the tech guy on the phone when ordering...which kind I needed...so he sent me these...what a ****** *******! Which are they?
deucedeuceEK
Oct 30, 2007 04:35 PM
SFlCrx
Mar 21, 2007 05:48 PM
GoFastMotorSports
Jan 17, 2005 02:43 PM
gt25CIVICex
Nov 27, 2004 09:51 PM
Seraph0
Nov 24, 2003 01:18 AM
