best supercharger cam profile
Old Jan 23, 2003 | 07:38 PM
vactor's Avatar
Default best supercharger cam profile
what would be ideal types of cams for a supercharged B series vtec? basically, would one look for long duration low lift intake cam and a medium lift shorter duration exhaust cam and then use cam gears to dial in the overlap (minimal i would think) etc? basic profiling for blower cams is what i am looking for. anyone have ideas?
Old Jan 23, 2003 | 07:55 PM
BudaKai's Avatar
Default Re: best supercharger cam profile (vactor)
Umm, what compression? How much 'boost'? Let us know and I'm sure we could tell you.
Old Jan 23, 2003 | 08:40 PM
vactor's Avatar
Default Re: best supercharger cam profile (tzsir)
would be for 'standard' compression. 'stock' boost'. again, this is not looking for a specific set of cams, just genreal guidelines as listed in the original post. is my thinking on this correct that a blown engine will do better with a general cam type? again, we are talking generically here.
Old Jan 23, 2003 | 09:45 PM
BudaKai's Avatar
You would generally want the exhaust cam to be bigger on supercharger applications. Higher lift same duration would be ideal. Tune out all but a very little duration. Like aroun 6-7 degrees. Best way to find out the exact setting would be DYNO, but if you want good clean burns with a stock head leave a little overlap.
Old Jan 24, 2003 | 04:10 AM
vactor's Avatar
ok. thanks. any explanation as to why one wants a high lift ex cam? what about the intake? good stuff to com i hope.
Old Jan 24, 2003 | 05:48 AM
keebler65's Avatar
i've always read on hostboard (all the JRSC gurus) that the best is the GSR cams for one reason or another (it probably fits the description mentioned above?)
Old Jan 24, 2003 | 12:38 PM
speedy108's Avatar
Default Re: best supercharger cam profile (keebler65)
Integra Type R exhaust cam and stock intake cam. Set of cam gears, leave the intake cam gear at 0 and retard the exhaust cam gear to -2 to -3 degrees. If it's a GSR then you might see an increase of 10 WHP.
Old Jan 24, 2003 | 02:24 PM
vactor's Avatar
Default Re: best supercharger cam profile (speedy108)
i hear the specific recommendations, but, let's say you were designing a set of cams. what types of properties would you want?
250r king
Mar 13, 2010 10:32 AM
CBR
Jul 31, 2005 08:51 PM
dvp95
Sep 5, 2003 01:12 PM
maximedx
Feb 4, 2002 09:16 PM
vwandhondaboy
Dec 26, 2001 08:55 AM
