Intake Manifold from H22 to F22?
Old Jan 23, 2003 | 05:14 PM
sauceman's Avatar
Default Intake Manifold from H22 to F22?
First, I tried the search and the topic doesn't seem to have been covered too often, I don't find anything about this.
Here's the situation: I am almost ready to change my timing belt on my OBD1 F22B1, in about a month. I am planning this, and on my list of to do/to buy things there are an adjustable cam gear as I said on another topic, and an FPR also. I plan on going to the dyno sometime soon, maybe this spring. I want to optimise my air flow if I am going to rise fuel pressure, and retard a litlle as well.
So I tell myself: H22's have larger TBs and I am too lazy to portfit them on my intake, and I figure the whole intake manifold from the H22 is well adapted anyway, so why not just swap the whole thing, from TB to the manifold, including injectors, etc.
Is this feasible? Or am I luring myself? If the ports fit, do the injectors and various solenoids and/or sensors adapt themselves to the F22B1 and OBD1 ecu? Are there particular years I would be looking at?
Thanks for the much appreciated info, guys
Old Jan 23, 2003 | 05:27 PM
93acclude's Avatar
Default Re: Intake Manifold from H22 to F22? (sauceman)
The two manifolds are very different. I am pretty sure that no part of the h22 manifold will fit onto the f22 engine, including the throttle body.
Old Jan 23, 2003 | 05:30 PM
Accord94DX's Avatar
Default Re: Intake Manifold from H22 to F22? (93acclude)
with a lil portmatching the h22a/h23a1 intake manifold and throttle body will fit.
the stud locations are the same, but the ports on the h-series are a lil larger.
Old Jan 23, 2003 | 05:37 PM
sauceman's Avatar
Default Re: Intake Manifold from H22 to F22? (Accord94DX)
Aight, so if I got my head ported and polished, then, swapping the h22 manifold with TB and everything would be something useful to do?
[Modified by sauceman, 9:38 PM 1/23/2003]
Old Jan 23, 2003 | 07:41 PM
mikeyvt's Avatar
i heard that u could use the h22a TB on the f22b2
Old Jan 23, 2003 | 07:44 PM
Accord94DX's Avatar
Default Re: Intake Manifold from H22 to F22? (mikeyvt)
you can.
Old Jan 23, 2003 | 07:49 PM
ArchAngel Sabastian's Avatar
New User
yes, have to line up coolant ports as well.
Old Jan 23, 2003 | 07:50 PM
gringo7718's Avatar
i have searched this but i never found any info for my 91 f22a1. will it work with another accord manifold?
Old Jan 24, 2003 | 02:35 PM
sauceman's Avatar
Default Re: Intake Manifold from H22 to F22? (ArchAngel Sabastian)
Right. Do you know how far off? Also, is there a particular H22 package I'd be looking for to work with my actual OBD1 equipment on my F22 manifold? (And I don't know the list, I know nothing about injection and anti-pollution)
Thanks.
Jeff
Old Jan 24, 2003 | 03:18 PM
Canonm7's Avatar
Look at this Euro R Manifold.
http://www.inlinefour.com/aceurinman.html
Old Jan 27, 2003 | 04:23 AM
Stew Pidasso's Avatar
Default Re: Intake Manifold from H22 to F22? (Canonm7)
Hmmm, it says that this Accord Euro-R intake manifold will fit on all H and F series heads.
Old Jan 27, 2003 | 05:17 AM
KCHybrid's Avatar
Default Re: Intake Manifold from H22 to F22? (Stew Pidasso)
As crazy as it sounds I plan on keeping my F TB when I do my H22a swap. Yes I like crusie controll that much...
EDIT: I will get it bored out at some point however to get rid of the restriction that its going to cause.
[Modified by KCHybrid, 8:18 AM 1/27/2003]
Old Jan 27, 2003 | 07:26 AM
Brandon's Avatar
Life is Suffering
One thing to look out for. They didn't say how well it would fit on there.
Old Jan 27, 2003 | 10:49 AM
SOHCArchangel's Avatar
Default Re: Intake Manifold from H22 to F22? (F22Turbo)
one major deal is getting the coolant port to line up aside from the portmatching to be done on the manifold and the head.
I am currently working on this and my solution that the coolant port on the f22 head is oval and the h22's is circular is to make the necessary sizing and tap and place a thread to barb fitting and route that line in the coolant in the necessary direction
Old Jan 27, 2003 | 01:36 PM
Brandon's Avatar
Life is Suffering
Default Re: Intake Manifold from H22 to F22? (SRMlimited)
wouldnt it be better just to buy an aftermarket TB
The H22 manifold is dual stage, which will help both high and low rpm power. The F22 manifold is so choked that it doesn't matter as much as you'd think.
boostedf22cd5
Oct 14, 2006 02:58 PM
gamblezhang
May 3, 2006 06:48 AM
kikeh22
Oct 13, 2004 05:46 AM
.jacob
Jul 22, 2003 02:08 PM
