Changing rotors on a EG hatch
Old Jan 23, 2003 | 03:36 PM
Nocturnal's Avatar
Default Changing rotors on a EG hatch
Is it hard or easy? A friend of mine needs his to be changed. I have a compressor and an imapct wrench. What else is needed? Thanks in advance.
Also, is it hard?
Old Jan 23, 2003 | 03:43 PM
-Whitey-'s Avatar
Default Re: Changing rotors on a EG hatch (psychotic)
well you wont need a compressor or a impact gun its pretty easy if you take the wheel off and look at it
Old Jan 23, 2003 | 03:49 PM
eg6ajk's Avatar
jack up the car and use something to hold it up safely (no not a jack)
take the wheel off first- 19mm
take the calipers off - 17mm (two srews - top and bottom)
get a philips and unscrew the screws on the rotor.
then tap it lightly and it should come off.
to install follow the steps back.
it should take about 30min with power tools if you really know what you're doing otherwise 2hr downtime. with beer drinkers or smokers 4hrs.
Old Jan 23, 2003 | 03:55 PM
kommon_sense's Avatar
Default Re: Changing rotors on a EG hatch (eg6ajk)
I've never successfully removed those screws holding on the rotors with a regular screwdriver. Each time I have had to break out the impact screwdriver and hammer and replace the screws with new ones. I'd recommend that you be prepared to do the same.
Also, spray the rotor down with brake parts cleaner before you install it, and it is recommended to install new pads whenever you change rotors.
Old Jan 23, 2003 | 05:40 PM
Echo7847's Avatar
Default Re: Changing rotors on a EG hatch (kommon_sense)
^ Power drill , I coulda used a regular screw driver on my rears, but decided to use the power drill. And yes replace ur screws, i didnt replace mine cuz i was really careful, but its always a good idea.
boostedickey
Suspension & Brakes
Dec 23, 2012 07:26 PM
ZCMeGone
13
Jun 25, 2007 07:59 AM
88crxhfb16
45
Jun 24, 2005 07:38 AM
Flux
Apr 13, 2003 11:05 AM
OEMaccord
Feb 7, 2003 02:28 PM
