Drop forks????
Old Jan 23, 2003 | 10:22 AM
X0's Avatar
X0
Default Drop forks????
I did a search...
I was wondering id there is a common swap for a 6g civic to have shorter forks. I have my car dropped a pathetic 1.5'', and that just isn't quite enough. I like the amount of suspension travel that i currently have so i don't want to change the springs. Is there another car out there with similar forks, just a bit shorter? Maybe another .5-1" is all i need.
Old Jan 23, 2003 | 04:07 PM
qcoffey's Avatar
Default Re: Drop forks???? (1.8L)
Suspension Techniques used to make a drop fork and control arm. They have since removed these from the market. Unfortunately unless you can find a used set your only options are to go with a lower spring or coilover.
Old Jan 23, 2003 | 04:18 PM
Shawn C's Avatar
In The Garage
Default Re: Drop forks???? (qcoffey)
if you cant find any, take your stock ones to a good machine shop, and tell them your desired specs. a reputable machine shop can make anything. a good friend of mine used to have a prelude w/ air-ride, and he got everything custom machined. it wasnt very expensive
Old Jan 23, 2003 | 05:45 PM
ismkv8s's Avatar
Default Re: Drop forks???? (22lbGS-R)
yes I think you can still get them from ryane motorsports (541-482-4822)they also make a drop rear trailing arm.
Old Jan 24, 2003 | 06:16 AM
X0's Avatar
X0
Default Re: Drop forks???? (ismkv8s)
Thanks. I wa hoping you'd say "oh just pull 'em off a '9x 'teg", but i guess it can't always be that easy.
different springs
no ****, really? j/k, i would but i really like the ride quality now as compared to when i had shorter springs. Skunk2 "coilovers" suck big ****.
Old Jan 24, 2003 | 06:43 AM
Shawn C's Avatar
In The Garage
Default Re: Drop forks???? (BAdMutHA)
yes they do. i figured as reputable a company as they are, they would make really good coilovers. my friend had a set on an accord, and it rode like absolute ****
FreshPurp
Suspension & Brakes
Sep 24, 2012 10:01 AM
deets
Suspension & Brakes
Jun 22, 2006 09:52 AM
EM1FORLIFE.
Suspension & Brakes
18
May 17, 2006 11:28 AM
Lou_Cypher
Nov 26, 2002 08:19 AM
S13 slide
Aug 13, 2002 05:58 PM
