my instrument lights went off? can't see $hit at night. pls help...
Old Jan 23, 2003 | 09:41 AM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Default my instrument lights went off? can't see $hit at night. pls help...
wat's going on. i checked all my fuses and everything looks ok. i remember the moment that they all went off--i was pluging my computer in. weird.
Old Jan 23, 2003 | 09:55 AM
Default Re: my instrument lights went off? can't see $hit at night. pls help... (iluvjasmine)
anyone???
Old Jan 23, 2003 | 10:22 AM
turbosol's Avatar
Check the fuse for you parking lights, I bet they don't work either.
Old Jan 23, 2003 | 03:06 PM
neof69's Avatar
Default Re: my instrument lights went off? can't see $hit at night. pls help... (turbosol)
I got a ticket for this very same thing. I just thought my cluster was out but turns out i had no running lights. . Replace fuse under dash.
Old Jan 23, 2003 | 03:09 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: my instrument lights went off? can't see $hit at night. pls help... (neof69)
when I first put in my JDM cluster, the lights didn't work at all- after I replaced them with brand new bulbs. I pulled out the cluster, unplugged and plugged back in, and they worked fine. I dunno, check the fuses or just wiggle the harness.
Old Jan 23, 2003 | 03:12 PM
pennies_hatchie's Avatar
Default Re: my instrument lights went off? can't see $hit at night. pls help... (Emerica)
same thing happen to me, turned out it was the wire harness (from the car) that was loose and all i had to do was jiggle it a little bit. the wire that controls the light in the cluster is on the top right of the cluster (at least in my 92-95 si cluster it is)hope that helps you...
Fo-Do Fanatic
Aug 12, 2009 09:12 PM
lluks_844
Jun 1, 2007 05:01 PM
egb18crt
Apr 1, 2007 09:26 PM
honda011
11
Aug 31, 2005 07:14 PM
mrbsponge
Dec 31, 2003 03:31 PM
