question about the V6 brake upgrade
Well the next round of upgrades on my 4g are the brakes. i just read that long post on the v6 brake upgrade, and printed all 33 pages of it.
I plan to use either the wagon or v6 calipers in the front with brembo blanks, and probably EBR pads. I think i might as well go with the SS brake lines while its all apart too. However, i am going to do a drum to disc conversion in the rear, using 5g accord EX discs, calipers, and trailing arms. I will just get the whole assembly from the junkyard.
My question is, when changing all this stuff out, should i be concerned with swapping out the power brake booster or proportioning valve or anything else in the brake system? I want to be sure i get ALL the parts i need before i begin so it doesn't turn into a month long project like so many others have.
Other than that - decide if you really need the dust shields (i didn't bother buying the Wagon ones). I didn't change anything else except the calipers, caliper brackets, rotors, and pads.
