my 94 cx hatch vtec wires with new swap
my cx hatch had a gsr motor in it before..but then returned it to stock cx motor..Im doing a jdm itr swap as soon as password:jdm gets there new motors in stock.. do you guys think it had all the vtec wires run already.. how can i tell? what do they look like?which wires is it again that iw ill need for the jdm itr 99 swap?thanks...
It depends but I would would say no. Chances are someone had the VTEC and extra sensors hard wired directly from the sensor to the ECU. In that case, they wouldve been taken out or cut when the motor was removed. Even if the wiring isn't there it's not going to be hard to get it back to the way it was.
i'll go check it out.. i hope its wired up cause im not sure how to exactly how to wire all the vtec wires up cause this is my first time doing the swap completely by myself....anyways thats for all the help i will check out the ecu right now..
Straits514
Apr 19, 2006 12:29 PM
Tad
14
Jun 29, 2004 09:22 AM
