Radio wiring
I'm hooking up a 00 SI cd player right now... went and picked up the harness today (part #: 04320-S84-999AH) I am assuming all the speaker wires connect to each other with the same colors as the car (91 civic), and also the wht/grn main power supply, and also the red/blk illumination signal wire. I have some other wires that I'm not sure if I use or what they go to... Does the sold blue wire atach to the wht/blu(constant power)? Then I have a wht/red, grn/red, small black, and solid red wire left... should these just be left unconnected? thanks for any help...
here's the colors for the civic, but it sounds like you already know those....
12V Switched Power - White/Green
12V Constant Power - White/Blue
Illumination/Dimmer - Red/Black
Chassis Ground - Black
Left Front(+) - Blue/Green
Left Front(-) - Green/Black
Right Front(+) - Red/Green
Right Front(-) - Brown/Black
Right Rear(+) - Red/Yellow
Right Rear(-) - Brown/White
Left Rear(+) - Blue/Yellow
Left Rear(-) - Green/White
the easiest way to wire it up, instead of getting a factory 00 harness, would have been to go to your local stereo shop and get a reverse harness from them (Metra p/n 71-1721 or Scosche p/n HA08R) then you would have a harness with universal aftermarket colors and you could wire it to your car using the chart above.
