Help Wiring Stereo
Old Oct 11, 2010 | 12:13 PM
GotamaHuy's Avatar
Default Help Wiring Stereo
1996 Honda Civic
So I am wiring up my stereo and the owner before me cut all the wires. I have put all the wires back and the radio works but everytime I turn off the car, my clock and pre-sets reset. Also, there is a red wire that isn't connected to anything, what is it, I tried searching but no luck. Also my stereo has a two plugs, red and white, what are these for? Better sound output to speakers?
Thanks
Old Oct 11, 2010 | 12:52 PM
joeymc13's Avatar
Default Re: Help Wiring Stereo
Constant 12V+ Blue/White - goes to aftermarket yellow
Switched 12V+ Yellow/Red - to red
Ground Black - to black
Illumination Red/Black - to orange (i usually don't use this wire)
Left Front (+) Blue - to white
Left Front (-) Gray/Black - to white/black
Right Front (+) Red/Green - to grey
Right Front (-) Brown/Black - to grey/black
Left Rear (+) Blue/Yellow - to green
Left Rear (-) Gray/White - to green/black
Right Rear (+) Red/Yellow - to purple
Right Rear (-) Brown/White to purple/black
Old Oct 11, 2010 | 01:01 PM
joeymc13's Avatar
Those two red/white plugs are prob preamp outputs, they would connect to an aftermarket amp. Any wires that you're not using, cap off.
If you still have the same symptom after you connect your appropriate wires, I have a feeling you'll need to check your fuses, particularly, a 7.5 amp fuse in your under hood fuse box.
Old Oct 11, 2010 | 08:29 PM
GotamaHuy's Avatar
thanks, my wires all match, ill check fuses tomrow
delsizzle1
Feb 21, 2011 01:09 AM
accordguy2001
Jan 28, 2008 05:30 PM
ph0shizzle
Dec 8, 2006 02:49 PM
DC2 Mang
Oct 19, 2006 05:25 PM
kyorishin
Audio / Security / Video
Feb 16, 2006 11:31 AM
