JDM Crank pulley...worth it?
Old Jan 22, 2003 | 05:13 PM
Thagreybomber's Avatar
Default JDM Crank pulley...worth it?
I've been looking at this post:
https://honda-tech.com/zerothread?id=390165
and was wondering if it was worth it. Someone on that post, posted that "it" (I'm guessing the crank pulley itself) would have to be rebalanced. Is this true? Is it an easy bolt on piece and will it 'free up' some power? TIA guys...and gals if any that answer.
[Modified by Thagreybomber, 6:14 PM 1/22/2003]
Old Jan 22, 2003 | 05:21 PM
Kataku2K3's Avatar
Default Re: JDM Crank pulley...worth it? (Thagreybomber)
It's not going to have any noticable gains... It does however look a lot better than stock especially if you are not running PS or A/C... Compared to an Unorthodox single underdrive pulley you're waaaay better off... The OE Honda CTR is balanced where as the unorthodox is not.. That just saves all your bottom end bearings and seals... Peace
stivic
May 7, 2005 08:56 PM
gtowni3
Oct 15, 2004 08:29 PM
mingbling
Apr 10, 2004 01:25 AM
3700 Vtec
Jan 21, 2003 05:55 PM
