squeak from new Konis... damnit.
Old Jan 22, 2003 | 02:54 PM
p0pe's Avatar
Default squeak from new Konis... damnit.
Me and some friends just installed some Koni yellows on my car, and theres a freakin squeak coming from the rear driver side strut when I hit small bumps and grooves in the road. I can't tell if its actually the strut thats damaged or if its just some metal to rubber contact etc. The car feels great but this squeak is just aggrevating, any suggestions? Anyone else with Koni yellows have noises like this?
Just some info: The Konis are sp3 series set on mid perch and on full softness with eibach sportlines, The bumpstops were not cut, it said nothing about cutting them in the instructions. All the other struts seem fine, there is occasional noise from the passenger rear strut too, but very rarely. Everything was torqued to spec from Helms.
Old Jan 22, 2003 | 03:21 PM
texan's Avatar
Default Re: squeak from new Konis... damnit. (p0pe)
Is there any play at the upper mounting point, and do they just squeek or occasionally knock (make a thud)?
Old Jan 23, 2003 | 09:29 AM
p0pe's Avatar
Default Re: squeak from new Konis... damnit. (texan)
Theres no play in the upper mount, just the squeaking and yes, occassionally a thud.
Old Jan 23, 2003 | 11:18 AM
NaVamous's Avatar
How much did you get your knois for? I'm looking into getting either Koni red's or tokico blues. Can't decide between the two, any major differences?? Which one is better for all around driveability?
Old Jan 23, 2003 | 06:55 PM
p0pe's Avatar
Default Re: squeak from new Konis... damnit. (NaVamous)
these are Koni yellows, sp3 series. I paid $528 from TornActive.com shipped. I haven't had any experience with either of those shocks, but I'd get the Konis just because of their company's reputation for quality. If I were you I'd also look into Bilstein HDs, I've heard really good things about them. It also depends on what type of springs your gonna be pairing those with.
Old Jan 24, 2003 | 09:19 AM
p0pe's Avatar
>Are these low-pitch squeaks are normal, and does the outside temperature
>have any effect on them?
The only noise that sometimes occurs with the shocks is that the upper seal that
the rod comes out of can get a little dry. This is more of a high pitched
squeak though and doesn't sound like what you're having problems with. As a
check, try spraying a little lubricant (WD-40 or something) on the rod and drive
it a bit. That will get the seal lubricated and, if that is the problem, make
the noise go away. Otherwise, it may be a bushing that the shock is attached
to.
The shocks will be affected by the cold for the first mile or so as the oil
warms up but no noise will come from them otherwise. If you have any questions,
please write back and let me know. Thanks.
Gordon
[Modified by p0pe, 12:20 PM 1/24/2003]
Old Jan 24, 2003 | 12:05 PM
emr88's Avatar
Someone correct me if I'm wrong here, but I think you should cut the bumpstops approximately 25mm (about an inch).
Could it be that the spring is not set correctly on the perch?
Old Jan 26, 2003 | 06:56 PM
p0pe's Avatar
Default Re: squeak from new Konis... damnit. (emr88)
Koni instrucitons said nothing about cutting bumpstops. The spring is correctly set on the perch, we took extra precautions to make sure things were correct. I'm just gonna try some WD-40 on the strut rod and see how it goes. Last night my friend road in the car with me who weighs over 250+ lbs and the car made no noise at all. I'm gonna lube up the strut rod and see how it goes from there.
[Modified by p0pe, 9:56 PM 1/26/2003]
Old Jan 26, 2003 | 07:35 PM
MattG's Avatar
New User
Let me take a stab at this......its only over very small bumps or "sways" like a parking lot.
Try adjusting the metal dust boot. Mine rubs the spring and squeeks in parking lots. I am going to try and switch to rubber dust boots so I don't have this problem.
Corruption
Suspension & Brakes
Mar 25, 2008 02:22 AM
mugenek007
Apr 1, 2004 01:29 PM
GreenBean
10
Apr 24, 2003 07:18 PM
p0pe
Jan 24, 2003 02:03 PM
