how much fuel pressure should i run in a high compression ls/vtec
Old Jan 22, 2003 | 01:21 PM
ls_vtec_b18a1's Avatar
Default how much fuel pressure should i run in a high compression ls/vtec
just wounder how much fuel pressure i should run in my ls vtec, its a b16 head, on a b18a1 block, with pr3 pistons.
Old Jan 22, 2003 | 04:50 PM
Default Re: how much fuel pressure should i run in a high compression ls/vtec (ls_vtec_b18a1)
Old Jan 22, 2003 | 05:10 PM
Kataku2K3's Avatar
What injectors? STOCK and are you running a stock ECU?? With that setup I would recommend a VAFC and atleast RC 310's.... 48-60psi should be adequate for a stock setup... I built my friend's LSVTEC using 81.25mm PR3 slugs and a PR3 head, on a stock GSR computer the car ran really lean and even after bumping up the FP to 56psi with the fuel maps trimmed up... I would try a VAFC at the least along with a your FPR set at ~55psi... Good Luck
IloveAPC
Oct 26, 2004 07:14 PM
riceball777
Apr 24, 2004 07:44 PM
riceball777
Feb 21, 2004 07:17 PM
gogou99
Oct 16, 2003 10:56 AM
