rods
h23's use the exact same rods as the F22's do, I had to buy Crower H23 rod's.. Nobody that i know of make's them, You can try Eagle to see if they make F22 Rods now, but last year they didn't.
http://www.tubas.net/~drew/ner/resou...tailedhec2.htm i got this from the other post
crower makes them. the h23 and f22 use the same thing.
B93747B - BILLET CROWERODS Honda Prelude SI, Accord 2.2
- $677.90
straight from crower.
[Modified by carolinaACCORD, 1:17 AM 1/23/2003]
- $677.90
Probe makes some that are fairly affordable, not sure of quality though... check out http://www.importperformanceparts.ne...ctingrods.html - I'm using Eagle H22 rods which are a little longer and having custom pistons made to my spec to mate up. Will get a slightly better R/S ratio as well.
What do you want to know? If you have stock length rods, just go to race engineering and get their f22 pistons.
If you want custom, here's what I'm using for my measurements, will rely on whatever company I go with to get me to my desired 9:1 c/r. Someone care to verify or argue these measurements?
Bore: 85mm or 3.346 (actual = 3.350)
Stroke: 95mm or 3.740
half of stroke = 47.5mm
Deck Height: 220.015mm or 8.662
Head: 50.6cc
Rod length: 143mm or 5.63 (for my H22 rods, stock = 5.580)
1/2 stroke + rod length = 190.5mm
working comp height: 29.515mm or 1.1806 (deck height - (1/2 stroke + rod length) )
Head: 50.6cc
