How long do ACT HDSS Clutches last?
Old Jan 22, 2003 | 09:31 AM
AzG35's Avatar
Default How long do ACT HDSS Clutches last?
Well, I'm trying to figure out if its time for my clutch to be replaced. I have had my ACT HDSS clutch for about 55,000 miles now. This is with probably with 150+ launches at the track, daily driven, and beat to hell. The last time I looked at it, probably 10,000 miles ago, it looked pretty good still, but the last few times at the track, when I do a 2nd gear waterbox burnout, I can smell it slipping/roasting. So, how long do these usually (supposed) to last? Any ideas?
Old Jan 22, 2003 | 12:03 PM
93EH6
Guest
Posts: n/a
Default Re: How long do ACT HDSS Clutches last? (AzSi22)
I have had mine in for 130 Miles no not 130,000 it is 130 and it works like a champ hope this helps
Old Jan 23, 2003 | 07:44 AM
AzG35's Avatar
Default Re: How long do ACT HDSS Clutches last? (autoxdelsol)
bump
Old Jan 23, 2003 | 08:47 AM
93EH6
Guest
Posts: n/a
What did i not help you very much
Old Jan 23, 2003 | 08:48 AM
GsR HtCh's Avatar
they are awesome. i know that the xtreme duty ones last forever. im not sure about the heavy duty. they should last longer than a stock clutch though.
Old Jan 23, 2003 | 08:59 AM
SoloSol's Avatar
Default Re: How long do ACT HDSS Clutches last? (98civichtchback)
55k is about what you would expect out of it. That is just a little more than i got.
You may be able to re-use the pressure plate. If you are on a budget. I have heard of a bunch of people doing that. Steve from sgt racing has reused one, had good results. Hit him up for some info he is super helpful. He is a member here.
Old Jan 23, 2003 | 09:20 AM
hybrider's Avatar
Default Re: How long do ACT HDSS Clutches last? (SoloSol)
ive put a good 15k on my ACT cltuch, and still perfect....
go for it
Old Jan 23, 2003 | 11:36 AM
AzG35's Avatar
Default Re: How long do ACT HDSS Clutches last? (hybrider93)
Hmm, maybe I just need to replace the disc and resurface the flywheel.
bowman06
Transmission & Drivetrain
Nov 21, 2008 08:02 AM
nitroaccord105
May 14, 2007 11:21 AM
13link EG
Jul 24, 2005 04:55 PM
LOwrestling2001
May 28, 2002 08:25 AM
quik92teg
Aug 18, 2001 08:40 AM
