SAE vs Actual HP? (big dyno pic)
Old Jan 22, 2003 | 08:27 AM
boostdGS's Avatar
Default SAE vs Actual HP? (big dyno pic)
If my car put 192.5 Actual HP at 6400 rpms. And 183.9 ft/lbs of Actual Torque at 4500 rpms. What would my SAE corrected Hp and torque numbers be?
Old Jan 22, 2003 | 08:57 AM
RaceTilIDie's Avatar
Default Re: SAE vs Actual HP? (boostdGS)
You need the other variables like altitude, temperature, etc.
Old Jan 22, 2003 | 08:59 AM
boostdGS's Avatar
Default Re: SAE vs Actual HP? (RaceTilIDie)
i was at sea level, and it was about 60 degrees
Old Jan 22, 2003 | 09:29 AM
martini's Avatar
you need the barometric pressure, the dew point, altitude, and air temp.
Old Jan 22, 2003 | 09:36 AM
The only other factor is either dew point or relative humidity. It sounds like you are probably really close to corrected HP already if not exactly on if the dew point was 58 degrees.
Glove
Dec 30, 2008 07:31 PM
Phoenix1
Aug 29, 2005 08:47 PM
typhoon
Feb 10, 2005 11:38 AM
