Garrett Oil Drain Flange with 5/8" hose barb fitting from Road Race Engineering
Old Jan 22, 2003 | 07:28 AM
T25 civic's Avatar
Default Garrett Oil Drain Flange with 5/8" hose barb fitting from Road Race Engineering
I have a t25 turbo and was wondering if this flange would bolt to my turbo. If so what size AN fittings would be 5/8"?
[Modified by T25 civic, 11:47 AM 1/22/2003]
Old Jan 22, 2003 | 08:07 AM
mos's Avatar
mos
Default Re: Garrett Oil Drain Flange with 5/8" hose barb fitting from Road Race Engineering (T25 civic)
The easiest AN adapter to find for that 1/2" NPT thread would probably be -8 AN. I'm sure you could find other sizes also though. The part you want is a 1/2" NPT to -10 AN fitting. If you use this fitting you will be discarding the 5/8" barbed fitting.
The RRE aluminum flange comes with a brass barbed fitting, but in your picture above, it is not shown.
Old Jan 22, 2003 | 08:18 AM
T25 civic's Avatar
Default Re: Garrett Oil Drain Flange with 5/8" hose barb fitting from Road Race Engineering (mos)
What about using part number 829010 from http://www.anplumbing.com/shop/shop1...pt=Swivel-Seal ?
It has a male thread size of 1/2" and uses a hose size -10.
Nick
Old Jan 22, 2003 | 09:27 AM
T25 civic's Avatar
anyone? I'm trying to figure this out before RRE opens so I can order it if I need to and get it overnighted cause I start my new job on monday and I have to have a car then.
Nick
Old Jan 22, 2003 | 09:31 AM
*Boostwerks*'s Avatar
THIS WILL NOT bolt onto a T-25
The bolt holes are spaced differently then a T3/T4 garret.
Old Jan 22, 2003 | 09:44 AM
T25 civic's Avatar
Default Re: Garrett Oil Drain Flange with 5/8" hose barb fitting from Road Race Engineering (Bryson)
FFUUUCCCKKKKK.........does anyone know if they make one like this for the t25?
Nick
Old Jan 22, 2003 | 10:08 AM
project dc2's Avatar
jon @ dropshop
USDM ED9
doa search
carbon fiber coupe
Jan 15, 2010 08:26 PM
StolenTeg
Mar 18, 2008 04:14 PM
LSEGHATCH
Sep 18, 2007 04:01 PM
catchthis92hatch
Sep 8, 2006 10:52 PM
