96-97 O2 Sensor after CAT
Old Jan 22, 2003 | 03:34 AM
phazeshifter's Avatar
Default 96-97 O2 Sensor after CAT
Hey,
I am really in the market for a high flow cat. I have DC Sports SS Headers, AEM CAI, Tanabe Super Racing Medalion exhaust, AEM Fuel Rail, etc. The problem is where the hell do I put my O2 sensor that is located after the cat(on 96-97's)? I was told that If I don't hook it up, properly, the computer will not get the right reading and mess up my air/fuel ratio because it isn't like stock. Others tell me to just drill a hole and pop it in, but that dosn't sound right. Any help or suggestions would be greatly appreciated.
Old Jan 22, 2003 | 04:30 AM
niedejb's Avatar
Default Re: 96-97 O2 Sensor after CAT (phazeshifter)
http://home.insightbb.com/~niedejb/o2.html
Works on all OBDII cars. (CL has the same innerds as an accord).
Old Jan 22, 2003 | 06:22 AM
Default Re: 96-97 O2 Sensor after CAT (niedejb)
Ok,
So What exactly do I need to solder in between the white wire though. It just sowns pictures but dosn't tell you what compacitor to use....It looks like I get a certaint copacitor and cut the white wire then solder the capaceter to it??? Thanks fur the help, just need more details. -Ryan
Old Jan 22, 2003 | 06:48 AM
carolinaACCORD's Avatar
are you going to be doing it yourself?
with most hi-flow cats, they are still OBD2 legal. any muffler shop would be able to cut a hole after the cat with a plasma cutter and put your o2 sensor back in.
as far as an o2 sensor simulator goes, check out this site. all of the parts are available at Radioshack.
http://jdmfan.com/technical/performa...sor_simulator/
Old Jan 22, 2003 | 07:35 AM
niedejb's Avatar
Default Re: 96-97 O2 Sensor after CAT (carolinaACCORD)
This is linked on my site. Guess you missed it.
The concept the same except the wire colors differ. White on the CL is the same as black on his site. Green is the same as his grey. The white on his schematic are the same as the black
Old Jan 22, 2003 | 08:04 AM
yours looks easier to make than his, niedejb.
it took me almost 3 hours, on and off (i was at work), to make his.
Old Jan 22, 2003 | 11:33 AM
Ok,
I understand much better now. I see where the 1/4 watt 1 Mega Ohm resister and the 1 micro farad capacitors go, but what do I do with the other parts it says you need....the PC Board Term and the ICB90 PC Board...the diagram dosn't show what they are, or where to use them...thanks for all the help guys. -Ryan
Old Jan 22, 2003 | 01:21 PM
niedejb's Avatar
Didnt use them.
Just solder them on the sensor like in my pics
92eghb
12
Feb 27, 2009 08:32 AM
bbhockey19
Oct 31, 2006 04:03 PM
sldcivic
May 4, 2006 02:12 PM
joshcivic00
Nov 11, 2005 10:49 PM
iam7head
Oct 9, 2002 02:26 AM
