what spark plugs for boost?
Ok, I've searched and come up with sooo many different answers, that I don't know what to go with. Can someone tell me what spark plugs I should get, where I can get them, and how much they are...but most importantly is what I should get. I've got a 99 integra GS, and I'm about to boost between 6-8 psi in the next week. What would you suggest?
NGK BCPR7ES-11 coppers and gap them to either .30 or .32 for best results..
Get them from you local parts store or just buy them at summit for about $2.40 a peace or something like that..
Adi
Adi
Adi
Adi
bkr7e-11 are for eclipses
do NOT use those, i saw many posts telling people to use those plugs for an LS.
they are the wrong plugs
I dont mean to take away your post but i have a question too
do i need to worry about my sparkplugs? im runnning 6.5 psi untuned with 12:1 fmu, inline pump, stock injectors, .45 bar spring.
Yes I'm sorry guys I meant 0.030 to 0.032" and not 0.30 or 0.32 or 30 feet
EvilgsrwBoost
I would go ahead and switch your plugs out because It will cause you to burn cleaner and will reduce hesitation if you have any, plus I don't think $10 is a big loss for that extra peace of mind..
Adi
http://home.mindspring.com/~vanillaice/crap/bkres.jpg
The bcpr and bkr look exactly the same on the engine side... The only difference I can see is on the side which is outisde of the combustion chamber. I've examined them closely.
go to http://www.sparkplugs.com
type in 6097 in the NGK box. select quantity. order. pay. done.
use some antisieze. torque to 14ftlbs. thank you drive thru.
Is the NGK BCPR7ES-11 the only set of plugs that I should use? I ask this because I can't seem to find that specific one anywhere in town.... Is there an equal alternative. If not, then I can have a shop special order them...but they said that it'll take about a week.
