MAP sensor wiring?
Old Jan 21, 2003 | 08:54 PM
asianspeed's Avatar
Default MAP sensor wiring?
What are the 3 wires coming out of the map sensor? 5 volt, ground, then sensor...is that right?
Old Jan 22, 2003 | 10:34 AM
Perfectionist's Avatar
Default Re: MAP sensor wiring? (asianspeed)
Wire color depends on the year and model, but...
Top and bottom wires are 5 volts and ground, the center wire is the sensor output.
Old Jan 23, 2003 | 10:10 AM
asianspeed's Avatar
Default Re: MAP sensor wiring? (Perfectionist)
I've got a '99 teg gs. The wires you said is probably for another car. I'm positive that it goes 5 volt, ground, sensor. I checked them myself. Thanks.
todd whaley
Nov 18, 2013 02:10 AM
Robs_B18c
Nov 4, 2009 08:39 AM
B18OnTop
Aug 16, 2005 01:44 AM
asianspeed
Aug 11, 2003 07:23 PM
