what setting on kyb agx for 93 honda accord ex?
Old Jan 21, 2003 | 08:50 PM
686's Avatar
686
Default what setting on kyb agx for 93 honda accord ex?
my 93 honda accord ex are sitting on 17" konig tantrums and i got eibach sportlines spring, which is a 1.8f and 1.7r drop, so i was wondering what setting i should put on the kyb agx? i'm an everyday driver, not really a racer. why do you recommend your setting?
Old Jan 21, 2003 | 08:57 PM
ratherbewalking's Avatar
Default Re: what setting on kyb agx for 93 honda accord ex? (686)
id try different settings, and see what you like. its not my car, nor anyone elses. to each his own.
id go with a stiffer setting bc you have 17's
Old Jan 21, 2003 | 09:57 PM
686's Avatar
686
Default Re: what setting on kyb agx for 93 honda accord ex? (ratherbewalking)
what setting makes a stiffer setting. i.e. lower in front and higher in back or vice versa?
Old Jan 21, 2003 | 10:05 PM
YodiBrodi's Avatar
higher # is higher damping which means stiffer ride.
not a racer? for comfort try 2-3 in front and 4-5 in rear.
personally i run 4 in front and 6 in back but it's rough.
Old Jan 21, 2003 | 10:11 PM
686's Avatar
686
Default Re: what setting on kyb agx for 93 honda accord ex? (YodiBrodi)
did you get progress camber kit only for the front or both front and rear? how come you didn't go with the eibach alignment camber kit and with progress instead?
Old Jan 22, 2003 | 09:46 AM
YodiBrodi's Avatar
i don't know if eibach's kit was available when i bought my progress group. it was a couple years ago.
i got it for front AND rear
Old Jan 24, 2003 | 11:41 AM
dynamite C1's Avatar
mine is #2 front and #3 rear
Old Jan 24, 2003 | 12:51 PM
686's Avatar
686
Default Re: what setting on kyb agx for 93 honda accord ex? (dynamite C1)
what kind of springs are you on? how harsh is the ride on the setting?
i'm planning on putting in either a 12" or 2 10" subwoofers which will load the back in down a little bit so what setting would be best do you think for that as an everyday driver too?
ttcheung97
Nov 16, 2009 03:03 PM
BBallz24
Jun 15, 2007 06:48 AM
92DAIntegraXSI
Mar 7, 2006 05:19 PM
iLLegaL
Jan 10, 2005 10:51 AM
hot93honda
Suspension & Brakes
Jan 9, 2005 08:24 PM
