will chirping tire at every redlight cause major damage ? (very dum question)
Old Jan 21, 2003 | 08:15 PM
State_of_mind's Avatar
Default will chirping tire at every redlight cause major damage ? (very dum question)
how can clutch last? i have exedy racing organic......2k on it........redline and racing it......another quesiton.....i adjust the push rod to push in more......i notice that the clutch engage more harst........if i shorten the push rod it engage okay....not like bang bang bang.......why? give me a clutch lessson.
thank you
Old Jan 22, 2003 | 05:45 AM
Stew Pidasso's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (State_of_mind)
Yes it will do major damage when chirping them at a redlight because the cross traffic, who has the green light, will hit you. Although I highly suggest you do this !!
Old Jan 22, 2003 | 05:48 AM
RaceTilIDie's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (Stew Pidasso)
Wise man say:
"A fool and his money are soon parted"
It applies perfectly to this thread.
Old Jan 22, 2003 | 05:57 AM
urbanlegend21's Avatar
New User
Default Re: will chirping tire at every redlight cause major damage ? (RaceTilIDie)
try english classes, they work pretty good
you are a fool if you are serious about this question
Old Jan 22, 2003 | 06:04 AM
YeuEmMaiMai's Avatar
it will kill your clutch, motor mounts, drive axles, tires and various suspension compoents.
it will also get you a ticket if the police in the area.....
Old Jan 22, 2003 | 07:10 AM
SOHCMAN's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (YeuEmMaiMai)
anytime you DRIVE at all you are ptting wear on your car, but especially if you are jack rabbiting like you obviously are. its just common sense. Its like saying"If I drink this beer will I have to ****?"
cheers
sohc
Old Jan 22, 2003 | 09:59 AM
philipkrotch's Avatar
clutch will cry for help and tires will be pissed off. so will any law enforcement in the area.
Old Jan 22, 2003 | 10:12 AM
h22accordturbo's Avatar
wise man once said "sometimes its kewl too cool to flo$$!" but then ur accord is slow as ****!
Old Jan 22, 2003 | 10:34 AM
Accord94DX's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (h22accordturbo)
just do society a favor and please smoke a blunt and kill yourself right now.
Old Jan 22, 2003 | 12:24 PM
MikeMAN's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (Accord94DX)
lol
Old Jan 22, 2003 | 03:15 PM
TypeSH's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (MikeMAN)
what is so cool about chirping tires anyways? anyone can buy cheapo tires and chirp them.
Old Jan 22, 2003 | 03:24 PM
brawl's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (TypeSH)
chirping tires is more time you're losing traction and less time you are actually putting real power to the ground...you move slower.
Old Jan 22, 2003 | 04:20 PM
cyrixvsp2's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (brawl)
http://www.clubsi.com
there's your new home
Old Jan 22, 2003 | 06:24 PM
Bantam's Avatar
2nd Coolest Person in DFW
Wow, this is a terrible question. I hope you arent serious. But I hope you have some money because this will destroy your car eventually Not to mention that If a cop sees you he will probably give you a ticket for anything he can think of for acting like a tool.
Old Jan 22, 2003 | 07:22 PM
Razor's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (tharptroy)
most the inbreds from hondasociety are migrating here unfortunately
Old Jan 22, 2003 | 07:46 PM
Desslok's Avatar
thank you
Pull up to stop light. Push in clutch, shift into 5th gear. Floor the gas, don't worry the rev limiter will protect engine. Slide your foot off the side of the clutch, this is called side-stepping(all REAL racers do this!). You will see smoke everywhere, this is normal, shows you are doing this right. j00 that smell, cuz it 0wNZ j00!
Old Jan 22, 2003 | 10:57 PM
WheAs MaI MojO's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (sp)
another clutch lesson:
Proceed by entering the freeway ramp. When you reach a speed of 80 mph on 5th gear, gracefully and gently* depress clutch and engage the shifter into 1st gear. Then, floor gas and dump clutch.
* Gear may not go in gracefully and gently. Put force.
Old Jan 22, 2003 | 11:22 PM
iam7head's Avatar
Okay..it's bad enuff as it is..let's lock this pos
Old Jan 23, 2003 | 04:49 AM
Default Re: will chirping tire at every redlight cause major damage ? (Razor)
This is Onetym408 who continually posts this garbage, keeps getting banned, and keeps coming back for more. Lets look at his greatest hits...
Posts on chirping tires...
https://honda-tech.com/zerothread?id=368136
https://honda-tech.com/zerothread?id=365278
https://honda-tech.com/zerothread?id=351453
Posts on his clutch and transmission problems
https://honda-tech.com/zerothread?id=341438
https://honda-tech.com/zerothread?id=373653
https://honda-tech.com/zerothread?id=369506
https://honda-tech.com/zerothread?id=368502
https://honda-tech.com/zerothread?id=366653
https://honda-tech.com/zerothread?id=361955
https://honda-tech.com/zerothread?id=359992
https://honda-tech.com/zerothread?id=360158
https://honda-tech.com/zerothread?id=354631
https://honda-tech.com/zerothread?id=316946
https://honda-tech.com/zerothread?id=310677
https://honda-tech.com/zerothread?id=308878
https://honda-tech.com/zerothread?id=303060
https://honda-tech.com/zerothread?id=303074
That's assuming you can read his slaughter of the english language and doesn't include all the new screennames he has made up over the past few weeks. Why don't you take a hint !!!
Old Jan 23, 2003 | 07:43 AM
seano's Avatar
please end yourself
Old Jan 23, 2003 | 08:08 AM
New User
Default Re: will chirping tire at every redlight cause major damage ? (seano)
chirp you tires at a light
get your car up to about 100 mph
drive it straight into a big *** wall
die a horrible, fiery *** death
Old Jan 23, 2003 | 08:16 AM
Nick M's Avatar
Default Re: will chirping tire at every redlight cause major damage ? (urbanlegend21)
enough, my patience is running thin
steveharrmr23
Jun 22, 2009 12:42 PM
NinjaTech
Aug 1, 2005 05:53 PM
rwcdrums
Mar 27, 2005 06:30 PM
Shinbo
Nov 14, 2004 07:03 PM
