u96 GS-R cams in a b16A SIR1. what all is needed and will it gain hp on a turbo application?
Old Jan 21, 2003 | 07:43 PM
Snail Tuning's Avatar
Default u96 GS-R cams in a b16A SIR1. what all is needed and will it gain hp on a turbo application?
ok I did a search and didn;t get much.
Ive read that people have gained up to 50 hp by using GS-R cams. well im goin to be turboing my B16 and was wandering if the GS-R cams would be a good upgrade. Also if they are what all is needed? Cam Gears? springs? retainers? valves? and will pistion valve clearance be an issue(stock pistions)?
thanks for all the help.
ok turns out there from a 97GS-R not a 96
[Modified by bmcc72, 11:55 PM 1/21/2003]
Old Jan 22, 2003 | 05:08 AM
Default Re: u96 GS-R cams in a b16A SIR1. what all is needed and will it gain hp on a turbo application? (bm
bump
Old Jan 22, 2003 | 11:33 AM
aright i just bought GS-R cams for $120 shipped. what do i need to install them?
i know someone had to have done this before let me know
Old Jan 22, 2003 | 12:17 PM
ULTRA911's Avatar
you don't need anything, should bolt up! $120 is a lot.
Old Jan 22, 2003 | 01:17 PM
ok i didn't know if i needed to change the springs like u do when u install CTR cams.
The GS-R cams only have 25,000 miles on them will they need reground or anything or can i just put them in?
would new springs an retainers help at all?
Old Jan 22, 2003 | 01:33 PM
ModAddict's Avatar
I was told the GSR cams will make a fair amount of power all the way to 9000rpm. He sugested Skunk 2 springs and retainers and move the rev limit up to 9k. He said that knowing I have stock internals. What do you think about that?
Beau Gotti
Nov 18, 2006 03:56 PM
CBURKE
14
Dec 15, 2005 09:21 AM
THEUSED
Northwest (Sales)
Sep 30, 2005 02:17 PM
TurboTeG4
Dec 15, 2003 07:17 PM
tek_civic
Sep 9, 2003 11:31 AM
