LS crank pully qustions alternator belt not fitting
Old Jan 21, 2003 | 06:08 PM
CRexcellence's Avatar
New User
Default LS crank pully qustions alternator belt not fitting
Is there a difference in crank pullys on a 91 integra automatic and manual? is the size different? The reason I ask is because my alternator belt is not fitting, I bought the pully used at a junk yard and bought a new belt from acura for a 91 teg. With the alternator as close to the pully as it can go on its bracket, there is no way I can get the belt to fit. So does anyone think that maybe the automatic 91 integra crank pully might be bigger then the manual 91 integra crank pully?
Old Jan 22, 2003 | 01:30 PM
Tuan's Avatar
Default Re: LS crank pully qustions alternator belt not fitting (jrx2002)
I don;t know the answer to your question but i know a solution to your problem. Just get a longer belt? I had to do that when i used a LS crank pully on a B20. Just my 2 cents
skwigelf
Aug 2, 2014 05:13 PM
zsiya
Sep 26, 2013 08:19 PM
vtec.dc2
Sep 11, 2007 05:58 PM
hatchlessrex
Mar 18, 2006 10:46 AM
DevinW
Feb 27, 2003 09:19 AM
