Too much tension on alternator belt = damaged crank?
Old 09-11-2007, 12:31 PM
vtec.dc2's Avatar
Default Too much tension on alternator belt = damaged crank?
Is it possible to damage crank if too much tension on alternator belt? damage as in cracked almost in in 2 pieces, or could this be from something else
Old 09-11-2007, 12:32 PM
philosofy1's Avatar
Default Re: Too much tension on alternator belt = damaged crank? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to damage crank if too much tension on alternator belt? damage as in cracked almost in in 2 pieces, or could this be from something else</TD></TR></TABLE>
yes, if the belt is to tight it will damage the pulley. why, how tight is your belt?
Old 09-11-2007, 01:55 PM
Darth ModerVader
Padawan's Avatar
Do you mean the crankshaft, or the crank pulley?
Either way, I can't imagine that sort of catastrophic damage resulting from excessive belt tension. Perhaps a bit of accelerated bearing wear, but not something cracking completely in half.
Old 09-11-2007, 01:57 PM
drtysohc's Avatar
^^^^+1
Old 09-11-2007, 02:04 PM
philosofy1's Avatar
Default Re: Too much tension on alternator belt = damaged crank? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Do you mean the crankshaft, or the crank pulley?
Either way, I can't imagine that sort of catastrophic damage resulting from excessive belt tension. Perhaps a bit of accelerated bearing wear, but not something cracking completely in half. </TD></TR></TABLE>
i never seen a pulley break in half, but i have seen it damage the pulley to where the crank pulley broke off the crank bolt, having to replace the pulley.
it happened once, sure did. a long time ago, on a 95 honda accord ex. i wish not to think about.
Old 09-11-2007, 02:15 PM
Darth ModerVader
Padawan's Avatar
Default Re: Too much tension on alternator belt = damaged crank? (philosofy1)
Interesting. And you're certain the cause was excessive accessory belt tension?
Old 09-11-2007, 02:20 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Interesting. And you're certain the cause was excessive accessory belt tension? </TD></TR></TABLE>
yes, atleast that is what my mechanic (god rest is soul) told me (this is when i was learning mechanics the hard way, by breaking crap). i have came a long way since then, a long way.
i also heard stories of timing belts being to tight than snapping off the cam gears.
Old 09-11-2007, 03:24 PM
circuitEG6's Avatar
check the harmonic balancer just inside the crank pulley. does the engine run rough, almost like a mis...
Old 09-11-2007, 05:58 PM
vtec.dc2's Avatar
the actual crankshaft
slowpro
10-03-2008 07:23 AM
LukieLuc
06-04-2007 08:36 PM
eastbay925
03-21-2007 06:13 PM
hatchlessrex
03-18-2006 10:46 AM
TeamTooQuick
09-11-2003 09:52 PM
Quick Reply: Too much tension on alternator belt = damaged crank?
