wrong bif my timing belt jumped a tooth on the cam gear could it cause a stumble in accelleration?
Old Jan 21, 2003 | 06:06 PM
civicracer1993's Avatar
Default wrong bif my timing belt jumped a tooth on the cam gear could it cause a stumble in accelleration?
i dont know if my ignition timing is off or if the belt is on the cam gear wrong but since i put a new head hasket on the car stumbles on accelleration a little and its st artin to bother me..
mike
Old Jan 21, 2003 | 06:21 PM
slomofo's Avatar
GDD Member
Default Re: wrong bif my timing belt jumped a tooth on the cam gear could it cause a stumble in accelleratio
It's your cam gear timing that's off. I would re-do your timing before you mess something up. Did you mark your belt position on the cam gear prior to it's removal?
Old Jan 21, 2003 | 06:30 PM
Shawn C's Avatar
In The Garage
if it was off a tooth it would hardly run...... did you torque the head bolts right??? and why did you change the head gasket?? if you blew the other one, you may have warped the head
Old Jan 21, 2003 | 06:35 PM
Evs-One's Avatar
Solbros Owns Me
go back and double check ignition/cam timing and all bolts to spec.
bradennicely
10
Apr 1, 2009 10:11 AM
97grnrs
May 10, 2007 03:25 PM
burgerbuddy
15
Sep 9, 2005 12:58 PM
EK4 hatchback
May 31, 2004 08:45 PM
corymedlin
Dec 29, 2003 10:57 AM
