JG Edelbrock Manifold Installation?
Old Jan 21, 2003 | 05:54 PM
420aNT's Avatar
Default JG Edelbrock Manifold Installation?
Just got my JG Edelbrock intake manifold . I can't seem to figure out were everything is supposed to go. There are a bunch of holes on the underside still and I am missing a spot for one of the sensors that has a vacuum line going into it. Also the attachments that are on the side of the stock manifold kinda looks like a throttle cable but Is on the opposite side? My manifold did not come with anything but the manifold. No parts no directions just the part. Someone please help me out with pics or something. I know someone is running this. I have an 01 GSR if that makes any difference.
Old Jan 21, 2003 | 06:02 PM
420aNT's Avatar
Default Re: JG Edelbrock Manifold Installation? (18gTeg)
ttt
Old Jan 21, 2003 | 06:27 PM
doughboy247's Avatar
installation is pretty much straight forward. you're going to need a vacuum for the brake booster, fuel pressure regulator and pcv valve. you can either plug up the rest of the holes or use those as vacuum sources for your turbo "stuff". as for the throttle cable, i used a LS cable bracket along with a SOHC throttle pulley. you will not be able to use the GSR throttle pulley or bracket. i hope that helps...
Old Feb 1, 2003 | 03:07 AM
420aNT's Avatar
Default Re: JG Edelbrock Manifold Installation? (doughboy247)
ttt
Old Feb 3, 2003 | 02:01 PM
RyanAutry's Avatar
good to know...
Old Feb 3, 2003 | 04:13 PM
Marauder's Avatar
Dang...who'd ya buy the mani from?? It should have installation parts and instructions with it! Call the edelbrock tech line and they will send you what you need to install it!
1badteg
Dec 19, 2006 06:57 PM
B18C5-EH2
Apr 12, 2005 02:32 PM
W O T
Welding / Fabrication
Jan 29, 2005 02:10 PM
APEX i GSR
Nov 29, 2001 06:13 PM
