How do you get your block so *bling* bling*?
Old Jan 21, 2003 | 05:40 PM
Kwuaymaikrup's Avatar
Default How do you get your block so *bling* bling*?
I see all these blocks that look so friggin nice and want to know what you guys are using to clean them. I've used Super Clean in the past but it always develops this white powdery looking residue after a few weeks. I'm sending my block out for sleeving and I want to clean it before the sleeves go in. Any suggestions? BTW it will be boosted so yes this is FI related.
TIA
Ryan
Old Jan 21, 2003 | 06:22 PM
johnisenglish's Avatar
Default Re: How do you get your block so *bling* bling*? (Kwuaymaikrup)
If it's any consolation, my block is nappy and covered in shoot
Yay for Open Downpipe
Old Jan 21, 2003 | 06:32 PM
speedymon's Avatar
Default Re: How do you get your block so *bling* bling*? (johnisenglish)
simply green and some hard work
Old Jan 21, 2003 | 06:38 PM
Slick GS-R's Avatar
Default Re: How do you get your block so *bling* bling*? (speedymon)
have it hot tanked at a machine shop when you pull it.........it will look **brand spanking new**
Old Jan 21, 2003 | 07:11 PM
paulzy's Avatar
Default Re: How do you get your block so *bling* bling*? (Slick_GS-R)
hot tanking a crusty motor will give you that dry clay look....what I suggest is to bead blast it before you bring it into the machine shop to have it hot tanked
Old Jan 21, 2003 | 08:41 PM
VaporTrail's Avatar
New User
Default Re: How do you get your block so *bling* bling*? (1320development)
bead blast it
Old Jan 21, 2003 | 08:44 PM
LS-hatch's Avatar
please explain bead blasting? What is is, how much, turnaround time, etc? I've never heard of it before.
Old Jan 21, 2003 | 08:55 PM
98civicEX's Avatar
Default Re: How do you get your block so *bling* bling*? (LS-hatch)
bead blast is similar to sand blasting w/ beads easiest way to explain it.
lazerus's Avatar
if you beed blast it.. be VERY CAREFUL and make sure you clean your block fully. any bit of that glass/sand in your engine means trouble for your bearings.
Old Jan 21, 2003 | 09:30 PM
Chrome Pipes's Avatar
Default Re: How do you get your block so *bling* bling*? (lazerus)
Did you try some brake cleaner? I tried it on my block and it worked pretty well. I think it was called Brakleen or something like that. We use brakecleaner on everything.
Old Jan 21, 2003 | 09:42 PM
highbrid's Avatar
Default Re: How do you get your block so *bling* bling*? (Chrome Pipes)
wont hot tanking warp aluminum?
Old Jan 22, 2003 | 03:44 AM
Phoenix GSR's Avatar
Default Re: How do you get your block so *bling* bling*? (highbrid)
no, I've had my head and block hot tanked
Old Jan 22, 2003 | 04:02 AM
Charlie Moua's Avatar
Default Re: How do you get your block so *bling* bling*? (Phoenix GSR)
well just pay more for the place that is doing your sleeves to clean your block!\
i'm sure almost any shops like that will have a hot tank or some sort of cleaning procedure.
Old Jan 22, 2003 | 04:18 AM
nsxmatt's Avatar
Default Re: How do you get your block so *bling* bling*? (Charlie Moua)
Use a wire wheel attached to a drill. Just go at it on your motor and it shines it almost like your polishing it. Same thing goes for the tranny. Use a metal polish afterwards and it get's even better. Doesn't take long at all either. Here is what mine looks like. (It's N/A but it works the same on FI )
Old Jan 22, 2003 | 05:27 AM
tony1's Avatar
Default Re: How do you get your block so *bling* bling*? (nsxmatt)
I've always bead blasted my blocks, they have a nice satin silver finish that way.
Old Jan 22, 2003 | 05:41 AM
shingles's Avatar
I used simple green and went to carwash place and blasted it.
Old Jan 22, 2003 | 06:15 AM
SlowB16's Avatar
Default Re: How do you get your block so *bling* bling*? (shingles)
I did the same.....The power washer does the trick!!!!
LUXXXX
Aug 16, 2006 08:16 PM
jfoster
Mar 26, 2006 10:29 AM
int3gra
Mar 2, 2004 10:02 PM
BoostedSi
Nov 3, 2002 08:00 PM
wtf
14
Sep 2, 2002 03:30 PM
