MSD BTM on a DIS system.
Old Jan 21, 2003 | 04:27 PM
kyle h.'s Avatar
Default MSD BTM on a DIS system.
does anyone know if this guy can be used as a stand alone? its not just an add on to the 6AL Ignition? Or I can use it on a DIS system?
Old Jan 21, 2003 | 05:32 PM
KingDsi's Avatar
Default Re: MSD BTM on a DIS system. (kyle h.)
That is an ignition amplifier with boost timing control. That is all you need. You can also go with an external coil and a modified cap to go with it.
Old Jan 21, 2003 | 05:43 PM
texan's Avatar
Default Re: MSD BTM on a DIS system. (KingDsi)
MSD makes a basic BTM unit that's separate from a 6 box (the 6BTM is just an integrated version), but neither can be used on a DIS multiple coil ignition (unless you use one per coil). They do however have several ignition products for DIS multiple coil pack designs, you can read all about them at msdignition.com. Their multichannel boost retard controllers are pretty powerful from what I hear.
madhatter2199
Jul 12, 2005 08:29 PM
NA90hatch
May 8, 2005 06:22 AM
out_of_order
Apr 18, 2004 08:26 PM
marques4130
May 10, 2003 12:16 AM
