S/T sway bar install
Old Jan 21, 2003 | 01:46 PM
96Prelord's Avatar
Default S/T sway bar install
I have searched and found helpful advice to purchase this sway bar and now i have to install it. I was wondering if one of ya'll have a pic of your install that you could post. If anyone that has done thier own install has any helpfull advice please feel free to post.
Thanks!!!
Old Jan 21, 2003 | 02:03 PM
Gennady's Avatar
New User
Default Re: S/T sway bar install (96Prelord)
Basically, it took me longer to jack up my car than to install the bar. It could not be any more straight forward. However, some people say you must drill a hole 1" forward of the stock swaybar endlink mounting hole in your trailing arm to mount the new endlink, and some say you dont. I did. Here is a pic of mine.
Old Jan 21, 2003 | 02:31 PM
96Prelord's Avatar
Default Re: S/T sway bar install (Wont be beat)
well im having trouble on the install of the endlink hangars, the hole doesn't seem to be large enough. Any advice?? BTW, your pic didn't work.
Old Jan 21, 2003 | 02:39 PM
Gennady's Avatar
New User
Drill it larger.
Old Jan 21, 2003 | 02:54 PM
all420's Avatar
Right click the picture, goto properties. Highlight the URL and click copy. Goto your browers URL insertion box and paster the URL there. And BAM...it's there.
Old Jan 22, 2003 | 11:57 AM
briq4's Avatar
If your car is an EX the holes should already be there, the only reason you would have to drill holes is if you have a car w/o factory bar. Also when removing the bolt from the subframe be sure to follow the directions and only remove one at at time, other than that it's cake.
Old Jan 22, 2003 | 12:21 PM
urbanlegend21's Avatar
New User
Default Re: S/T sway bar install (briq4)
are the 96 setups different than the 94's? If not the ST sway bar requires drilling
Old Jan 22, 2003 | 12:25 PM
2000Accord5sp's Avatar
I have an EX and the directions say that if you have holes, to drill another set of holes 1" away from the existing one. I did that and it seemed to install perfectly so I would stick to the directions.
Old Jan 22, 2003 | 03:05 PM
Gennady's Avatar
New User
Default Re: S/T sway bar install (2000Accord5sp)
Had an EX, drilled holes. I would imaging having the enlinks as verticle as possible would be best.
Old Jan 22, 2003 | 03:13 PM
TypeSH's Avatar
for you guys who drilled holes, what year and trim is your accord? and did it come w/ a stock rear sway bar? I have a 94 ex and ive heard mixed responses... some w/ 5th gens had to drill holes some didnt. kind of odd considering I thought we shared the same parts in the rear for the entire generation.
Old Jan 22, 2003 | 05:34 PM
Default Re: S/T sway bar install (TypeSH)
All EX 5th gens come with sway bars. So they will have holes already but those holes are for the stock sway bar. ST specifically says to measure 1" from the existing holes (if you have an EX) and drill new holes.
Old Jan 22, 2003 | 06:21 PM
mr2td's Avatar
New User
Even if you have an EX you still have to drill holes. I did on my 92 EX.
Old Jan 22, 2003 | 07:32 PM
Razor's Avatar
Default Re: S/T sway bar install (mr2td)
i have a 94 ex and still had to drill holes, what a pain since i didn't have the right tools with me at the time.
Old Jan 22, 2003 | 08:15 PM
Gennady's Avatar
New User
Default Re: S/T sway bar install (Razor)
92 EX. Drilled.
Old Jan 22, 2003 | 08:30 PM
Accord94DX's Avatar
94 DX coupe. Not drilled.
Old Jan 22, 2003 | 08:58 PM
carolinaACCORD's Avatar
Default Re: S/T sway bar install (Accord94DX)
96 LX. Drilled.
(just following the trend)
Old Jan 22, 2003 | 10:27 PM
TypeSH's Avatar
Default Re: S/T sway bar install (carolinaACCORD)
you guys who drilled, coupes or sedans?
Old Jan 23, 2003 | 05:52 AM
Gennady's Avatar
New User
92 EX Sedan. Granted, I didnt have to, I could have used the stock holes, but I was simply following manufacturers directions.
Old Jan 23, 2003 | 06:00 AM
Accord_Munch's Avatar
Mine are not drilled ... now when you say you drilled 1 inch away from the hole, is that one inch closer towards the rear of the car?
Old Jan 23, 2003 | 06:26 AM
Razor's Avatar
sedan
Old Jan 23, 2003 | 08:37 AM
toadlax's Avatar
'99 sedan not drilled
Old Jan 23, 2003 | 10:02 AM
Import Driver's Avatar
I have a 96 LX sedan...no drilling. I love my sway bars!
what instructions?
Old Jan 23, 2003 | 10:12 AM
Gennady's Avatar
New User
Default Re: S/T sway bar install (Accord_Munch)
1" forward.
Old Jan 23, 2003 | 10:16 AM
briq4's Avatar
my guess is that you would go towards the front of the car due to the origial hole already being close to the brake line, although I'm pretty sure the instructions said if the hole is already there no drilling necessary. They said if the hole isn't htere then you drill one inch in front of the stud (I never looked but apparenlty there is a stud right there)
Old Jan 23, 2003 | 12:28 PM
sedan
