Vehicle Speed Sensor ?
Old Jan 21, 2003 | 10:39 AM
RCautoworks's Avatar
Default Vehicle Speed Sensor ?
I got this code 2 times when I was driving, the first time it happen I was turning, the turn was right after a hill I went over. So I thought maybe it was because I was turning. I reset the ecu and everything seemed fine. The next I got it I was coming down the same hill but I did not turn. So it seems to go on everytime I go down a hill. I read some other post about this problem and it seems water could get inside it, atleast I thought I read that. Basically my question is, me going down hill, does that have anything to do with the code ?
[Modified by 90blackcrx, 1:50 PM 1/21/2003]
Old Jan 21, 2003 | 11:18 AM
EF_LSVtec's Avatar
Default Re: Vehicle Speed Sensor ? (90blackcrx)
usually when you're slowing down you'll get the code if you're VSS or speedo is bad.
Old Jan 21, 2003 | 11:40 AM
whichone's Avatar
cant you test it's output in A/C volts??
Old Jan 21, 2003 | 12:23 PM
Well I just got it again, and yes it was when I was slowing down. So how do I test it ? My speedometer seems fine. Could this be caused by a bad ground, also I heard that the vss usually does not go bad. Maybe its just loose. By the way, will my old vss work that was on my dx engine. I have a b16 now.
[Modified by 90blackcrx, 3:25 PM 1/21/2003]
Old Jan 21, 2003 | 01:20 PM
zCivic's Avatar
1. Take the guage cluster out, this mean unhook everything you you have entire cluster out
2. Break off a pencil and put it where the spedo cable went.
3. Put an ohmmeter on the 2 screws under where the spedo cable went. There should only be 2 and there right next to each other.
4. There should be CONTINUNITY between the 2 termanals, then turn the pencil counterclockwise and it should be 4 times with each revolution, now I'm unsure if this means 4, 8, 32 ohms or what but thats what the helms says
[img]C:\My Documents\My Pictures\91-23-92.jpg[/img]
hope this links works
[Modified by zCivic, 5:23 PM 1/21/2003]
Old Jan 21, 2003 | 03:35 PM
EF_LSVtec's Avatar
If you cant find a B16 VSS, I have one with the cable and clips too that I used for 3 months. I upgraded to an electronic VSS to work the JDM cluster. Let me know if you want it, I paid $70 shipped w/ cable. I'm paypal verified too.
Old Jan 21, 2003 | 04:24 PM
zCivic's Avatar
Default Re: Vehicle Speed Sensor ? (EF_LSVtec)
I may be wrong but only the SI-R and 92+ Civic use the VSS on the tranny. You can use the VSS on the tranny but you have to rewire for it.
ufakeit
10
Sep 8, 2009 05:34 PM
DeltaCharlie2
Nov 5, 2007 12:08 PM
GRANDE7652
Jun 2, 2006 05:19 AM
crxsi_rcr
Mar 20, 2002 06:08 PM
