how do i get 300whp out of a turbo 2nd gen B16a
Like the title says, I want to get around 300 or so whp. I have a 2nd gen JDM B16a. What engine mods do I need and what turbo should I run?
These are only my suggestions. There are many ways to achieve that amount o power but this is how id do it:
Get the block sleeved
pistons
rods
hondata
injectors
intank fuel pump
t3/t04e turbo
decent intercooler
tial wastegate
3" dp and exhaust
(im sure im leaving something else out)
correctly TUNED with enough boost that will get you about 300hp
pistons
rods
hondata
injectors
intank fuel pump
t3/t04e turbo
decent intercooler
tial wastegate
3" dp and exhaust
boost 10-12 psi with a t3/60-1 .63 a/r on stock motor..done!
I like that response!hehe
dont forget the fuel upgrades tho!!!
Technically you could build the whole thing with sleeves, pistons, rods, etc.
But 300 WHP is not impossible on a stock B16.
I'd say 12 PSI, tuned RIGHT, and your getting real close.
If you want it to be easy, JE 8.5:1 pistons, and slap on 15 PSI+.
How much would it cost to resleeve the block. Is that something that most people could install or does a specialty shop have to do it. Is it safe to run stock internals at 12-15 psi?
I would think if u had a full standalone setup and a great tuner its safeand u would definatly make the HP! for the more budget the 440cc's and an afc might make some #'s at around 10-12! but one is never certain! not every motor is the same
Here is the cheapest recepe:
Turbo Kit
Inline Pro Gasket
15psi
300whp like butta!!!!
Adi
Turbo Kit
Inline Pro Gasket
15psi
Adi
Turbo Kit
Inline Pro Gasket
15psi
Adi
then he blows a rod through the block "like butta"
Turbo Kit
Inline Pro Gasket
15psi
Adi
Inline Pro ran a second gen integra with a stock b16a motor using 2 headgaskets with a 50 shot, 15psi, and rev hard kit to a 10.1 @ 137 and that motor is actually still running... Enough said.
Adi
Turbo Kit
Inline Pro Gasket
15psi
Adi
Just another quick note for the non belevers.
Adi
Turbo Kit
Inline Pro Gasket
15psi
Adi
Adi
hell, i run a stock b16 with an inline head gasket at 14.7 psi daily and have even seen 17-18psi at the track with only 370's, an safc, and a fmu!! and i am almost positive i am making 300hp(wihout a doubt)!!!
EDIT: point of the story............it can be done inexpensivly, but it depends on you and the strength of your motor!
[Modified by boostin b16, 12:47 PM 1/22/2003]
Turbo Kit
Inline Pro Gasket
15psi
Adi
Adi
Turbo Kit
Inline Pro Gasket
15psi
Adi
Adi
[Modified by Kamin, 10:46 AM 1/22/2003]
there is no way they did that with a stock fuel setup. or the weak setup that came in that kit. im not saying its impossible to do with an ILP headgasket but not with a crappy fuel setup. injectors a good pump and good tuning are a must.
gibson_standard_sg
Sep 22, 2008 05:29 PM
99TurboBlue
Apr 9, 2007 08:50 AM
