wiring harness question
i kno this may have been asked b4...but...which ones can be used and is there one wiring harness that is better than the other for a B16A in a 88 Rex Si??
Oh gosh no... besides level of difficulty, what else could be important? It's not like you'd get extra performance from using a JDM wiring harness, y'know
i was always told that he stock JDM wiring harness has things wired differently to make room for the brake master cylinder, the steering, and a few other things being on the right hand side of the car.
i will admitt to possibly being wrong though-ive never done it first hand.
[Modified by JHMeg8, 7:25 AM 5/17/2001]
Well i wired mine from the way on shadows site and i'm up and running just fine, i had to make a couple but other then that it's running quite well now, or maybe i just got lucky.
[Modified by 91sifreak, 3:10 PM 5/17/2001]
i was thinking more along the lines of...maybe the harness from a newer car would be in better condition than that of a older Si harness??? Maybe that would make a slight difference...not in performance, but in reliability..eg. not having problems and so forth??
So what harness do you want to use, correct me if i am wrong but i believe this harness really is the one to use. The 88-91 is the one i used and added four wires ( actually 5 including the ground ) to a seperate little harness of my own creation ( it on that site the shadow said to check out ) and mine runs fine, as long as the harness you are going to use is in decent condition, use it. But there maybe a better way, i don't know everything or try to say i do.
I don't believe so, but like i said i don't everything. I have another Si harness that is in pretty good condition, if you would like it I could possibly sell it to ya ( For like nothing ).
the connections where the engine harness plugs into chasis harness are different on the newer harnesses-so you would essentially be creating an entirely new harness for everything to work. Your best bet if your worried about it is to get a harness from the same generation thats in better shape.
streetracerof06
Sep 2, 2005 07:16 AM
