HAVE A SHORT. . . need help to find the problem
Old Jan 20, 2003 | 09:17 PM
Hybrid-B's Avatar
Default HAVE A SHORT. . . need help to find the problem
I have a 95 civic Ex coupe, just recently i installed the factory foglights. Well heres the problem whenever i turn them on, the power wire going from the harness to the switch gets really hott. And the light on the switch turns on and off frequently, and also the HVAC control lights are only halfway illuminated. My friend said there is a short somewhere, and i cant find it. Can anyone help me out here. . Thanks
Old Jan 20, 2003 | 09:34 PM
Shawn C's Avatar
In The Garage
Default Re: HAVE A SHORT. . . need help to find the problem (Hybrid-B)
so- im guessing that you wired them up with ~18 ga wire to a ghetto autozone switch, right?? you need to use ~14 ga wire, and run them from a high-amp relay straight to the battery or high-amp 12v source.
Old Jan 20, 2003 | 09:47 PM
Hybrid-B's Avatar
Default Re: HAVE A SHORT. . . need help to find the problem (22lbGS-R)
no actually its the factory harness and switch. . i pulled it outta my friends HB. So i honestly dont know what it could be.
Old Jan 20, 2003 | 09:50 PM
Shawn C's Avatar
In The Garage
run new grounds, that should totally solve the problem
edit- by the way, what part of TN are you in? im from knoxville
[Modified by 22lbGS-R, 6:51 AM 1/21/2003]
Old Jan 20, 2003 | 09:51 PM
Hybrid-B's Avatar
ok thanks a lot. . ill try that tomorrow.
Old Jan 20, 2003 | 09:55 PM
Shawn C's Avatar
In The Garage
no prob, 1 more thing, you might want to put in a bigger fuse for those lights, since you are pulling more current now.
tomii.dc-5
Honda Civic (2006 - 2015)
14
May 3, 2009 01:02 AM
fwdftw
Aug 21, 2006 05:42 PM
jakscivic
20
Jul 6, 2006 12:52 PM
jakscivic
Jun 21, 2006 04:42 PM
Joon Joon
27
Oct 23, 2005 05:49 PM
