VAFC display woes.... not showing up when cold
Old Jan 20, 2003 | 08:01 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default VAFC display woes.... not showing up when cold
so i have a problem with my VAFC.... let's get the story:
i bought the unit in july '02, hooked it up myself, everything worked/works perfectly fine. i used to mount it on the dash in the 100 degree cali summer heat, and parked it at a community college parking lot 4 days a week.
fast forward to today, it is now mounted above my rearview mirror. about a month ago, i turned the car on after a late night (around 2 am) to head home. it was pretty damn cold, and i noticed that my VAFC display was missing a line or two....
after about a month i've concluded that it only does that when it's cold, and once it gets fully warm (i.e. you can feel it hot to the touch) it's fine. but it seems to be getting worse. the blank lines have spread up to 3 or 4, and i don't know what the hell is going on. it comes back once it's warm, yes, but why is it doing this? just because it's bitter cold? i'm kinda worried. here's what it looks like cold:
what do you think it could be?
Old Jan 20, 2003 | 10:02 PM
brinks's Avatar
Default Re: VAFC display woes.... not showing up when cold (dLo GSR)
I dont know how the cold usually affects a vacum flourescent display like the VAFC has, but it can freeze/ruin LCD displays like cellphones have. How cold was it? Cellphone screens can become slow to respond/dim when the temp dips into the low 30's and ruined(burst) if it dips into the 20's or below. Check the VAFC manual to see what the operating temp for the unit is.
[Modified by brinks, 2:07 AM 1/21/2003]
Old Jan 20, 2003 | 11:26 PM
erniecars's Avatar
Default Re: VAFC display woes.... not showing up when cold (brinks)
It could be a cold solder joint. This happens when the unit is in extreme temperatures. After a while the solder joints can become brittle from temperature changes and cracks. The connecton will be loose until the unit heats up and metal expanse ever so slightly reconnecting the joint. you may want to just open the unit and check the solder joints for tiny cracks or resoldering everying. All you have to do is melt the solder or just add a tiny bit to each connection.
Old Jan 21, 2003 | 03:07 PM
Default Re: VAFC display woes.... not showing up when cold (erniecars)
hmm ill have to try that...
the thing is, its not like extreme temperatures... cali weather ranges from like 50-100 yearly...
Old Jan 21, 2003 | 04:18 PM
obd2gsr's Avatar
could be this one. my cell phone does that. i live in the bay area, too.. it's been pretty cold out at night.
Old Jan 21, 2003 | 06:13 PM
altoid's Avatar
Default Re: VAFC display woes.... not showing up when cold (obd2gsr)
from my understanding, which could be completely wrong, the electrons move the liquid crystals to form proper images and if its cold the LCs could be frozen together, happens with my calculator all the time
Old Jan 21, 2003 | 07:34 PM
erniecars's Avatar
Default Re: VAFC display woes.... not showing up when cold (altoid)
it could also be moisture inside the unit shorting out the display
captaindammit
Mar 10, 2008 09:17 AM
Mefain
Nov 15, 2004 04:24 PM
Behan
Jan 27, 2004 06:54 PM
Hybrid 350GT
Nov 8, 2002 02:14 PM
