Rebuilding motor but have 2 quick questions (rings+stem seals)
Old Jan 20, 2003 | 06:41 PM
Wicked Sol's Avatar
New User
Default Rebuilding motor but have 2 quick questions (rings+stem seals)
Could I use b16a2 rings on a b18a piston?
Also I removed the valves from the head to clean them and do a rebuild but changed my mind. The valve stem seals are only a few hundred miles old but should I replace them anyway or can I just put the valves back in? I never cleaned or contaminated the seals in any way but I'm not sure how easy they rip from removing the valves.
Old Jan 20, 2003 | 06:51 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Rebuilding motor but have 2 quick questions (Wicked Sol)
You can use the B16 rings and I would just reuse the seals since you said they have only a few hundred miles on them.
Old Jan 20, 2003 | 07:43 PM
McFly's Avatar
Default Re: Rebuilding motor but have 2 quick questions (GapxGuy)
Yea. What he said!
houstonteamer
Oct 23, 2009 08:56 AM
ghosthatch
14
Mar 25, 2009 08:55 PM
vtecb20coupe
30
Dec 23, 2003 06:38 AM
