Blue smoke
Old Jan 20, 2003 | 05:43 PM
91_hatch_si's Avatar
Default Blue smoke
when i rev the **** out of my 91 si blue smoke comes out, but when i drive normal (under 4000rpm) it is regular, what should i do?
Old Jan 20, 2003 | 05:46 PM
bryant's Avatar
Default Re: Blue smoke (91_hatch_si)
your burning oil. get that checked out.
Old Jan 20, 2003 | 05:48 PM
91SIvic's Avatar
Default Re: Blue smoke (Bryant)
seals.. i got the same problem... fixing it with a 93 b18a1
Old Jan 20, 2003 | 09:33 PM
Default Re: Blue smoke (91SIvic)
seals???
what kind of seal
Old Jan 20, 2003 | 09:37 PM
shorti's Avatar
piston ring i think
Old Jan 20, 2003 | 09:42 PM
shortyz's Avatar
Default Re: Blue smoke (shorti)
rings
does any newbie know how to work the search button
jesus christ!
Old Jan 21, 2003 | 06:20 AM
WuShu's Avatar
New User
Default Re: Blue smoke (shortyz)
dont go and change a part on a whim, check everything then diagnose what it is. It could be a few things. If the smoke is blue, you are definitely burning oil tho. Check everything.
Old Jan 21, 2003 | 09:39 AM
JoshDM's Avatar
Default Re: Blue smoke (HondaCRX)
could be piston rings, rocker arm seals, or valve guide seals
Old Jan 21, 2003 | 10:29 AM
charjacq's Avatar
New User
Run a compression or leak down test. That will tell you what the problem is. It's usually not worth fixing it at this stage as you would have to change hundred more parts at the same time. Just do a swap.
LaOXXKIDD
Aug 15, 2009 12:05 PM
KevinSmith88
Feb 23, 2009 04:20 PM
dexGSR99
Feb 6, 2006 04:27 PM
X-cement-filled-EG-X
Apr 5, 2004 04:01 PM
Cyber ITR
Jan 7, 2002 05:10 PM
