Valve Adjustment
Old Jan 20, 2003 | 05:10 PM
Junglist's Avatar
Default Valve Adjustment
Do you disconnect the battery when doing this?
Old Jan 20, 2003 | 05:54 PM
GSRfoedoe's Avatar
Default Re: Valve Adjustment (Junglist)
no
Old Jan 20, 2003 | 08:11 PM
B2FiNiTY's Avatar
You can but there is no need really.
Old Jan 20, 2003 | 08:13 PM
b19coupe's Avatar
No. I use the battery/starter to bump the engine around to do each set of valves.
Old Jan 20, 2003 | 08:24 PM
uNF$@#!'s Avatar
Default Re: Valve Adjustment (b19coupe)
interesting...
i would use the manual crank.
can you actually use the starter? how would you do this without reaking havoc...
[Modified by Soup ****, 12:29 AM 1/21/2003]
Old Jan 20, 2003 | 08:29 PM
TypeR 599's Avatar
that will take some time to get lobes where you need them.
Old Jan 20, 2003 | 08:49 PM
b19coupe's Avatar
Default Re: Valve Adjustment (TypeR 599)
Actually, I use a remote starter button. Have been using it almost everyday for about [ stops, scratches head] 20 years. Have it down. One complete revolution of the camshafts and all the valves are done.
zerovandez
May 11, 2011 07:58 PM
Itu
Feb 13, 2008 11:36 AM
jean282
Jan 13, 2008 08:38 PM
soon2bdropped
Sep 1, 2006 02:12 PM
NoahSukata
Oct 30, 2005 08:59 PM
