Symptoms of a Burnt Valve? AGGGGHHH!
Old Jan 20, 2003 | 03:58 PM
Blaze45's Avatar
Brrraaaap!
Default Symptoms of a Burnt Valve? AGGGGHHH!
Ok so I get my B20 from HMO and I was changin the plugs and in the no.1 spark plug runner IC oil. I thought ok just from shippin ya know? So today I pull off my IM to have a look around and I look @ the No. 1runners @ the valves. The very first in. valve looks like its taost. Very black and oily. So Ic if I can scrape it off and then I turn the carnk and when the valve closes (should be completely seal'd correct?) the carbon would blow around above the valve!!!!! Do I have a burnt valve? Or could this be worse... burn'd/busted rings/lands? The engine is still out of the car so any help would be great. Thanks.
O and if anyone has pictures that would be really sweet!
Blaze
[Modified by Blaze45, 1:00 AM 1/21/2003]
Old Jan 20, 2003 | 04:27 PM
B18EG6's Avatar
Default Re: Symptoms of a Burnt Valve? AGGGGHHH! (Blaze45)
do a leakdown test with the cylinder at TDC and see if air comes out of the intake/exhaust.
here is what mine looked like...the car would not idle, due to the masssssive hole
Old Jan 21, 2003 | 06:18 PM
Blaze45's Avatar
Brrraaaap!
What causes burnt valves?
Old Jan 22, 2003 | 04:33 PM
B18EG6's Avatar
Leaning out, heat...
Old Jan 22, 2003 | 06:15 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Symptoms of a Burnt Valve? AGGGGHHH! (B18EG6)
Huh? Please explain.
Old Jan 22, 2003 | 06:53 PM
AzG35's Avatar
Default Re: Symptoms of a Burnt Valve? AGGGGHHH! (GapxGuy)
Improper valve lash clearances (too tight) will cause a burnt valve
Old Jan 22, 2003 | 08:05 PM
lazerus's Avatar
Default Re: Symptoms of a Burnt Valve? AGGGGHHH! (AzSi22)
engine goes too lean, valve heats up, becomes weak, breaks off.
aftermarket valves good way to go.
Old Jan 23, 2003 | 08:10 AM
B18EG6's Avatar
Default Re: Symptoms of a Burnt Valve? AGGGGHHH! (lazerus)
Huh? Please explain
Im sorry, I was under the same impression...Isnt this correct?
Old Jan 23, 2003 | 08:17 AM
Doodoo's Avatar
I burnt a Ferrea the same way. Proper tuning is the way to go!
Robotoyaki
Jan 1, 2010 02:10 PM
XkjeldorX
Jun 14, 2006 03:56 PM
SiCRX90
Nov 6, 2005 06:15 PM
petrv
Aug 26, 2005 02:26 PM
95LSS
Aug 30, 2003 08:08 AM
