Removing axle from intermediate shaft?
Old Jan 20, 2003 | 03:25 PM
-CP-'s Avatar
Default Removing axle from intermediate shaft?
i got a b18c eg and i was wondering do i remove the shaft from the intermediate shaft, or just remove the intermediate shaft?
thanks
Old Jan 20, 2003 | 03:29 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Removing axle from intermediate shaft? (-CP-)
remove the axle from the intermediate shaft, theres no need to remove the intermediate shaft, rarely ever
Old Jan 20, 2003 | 03:38 PM
-CP-'s Avatar
Default Re: Removing axle from intermediate shaft? (SIXTYdashONE)
ok
how do i remove the axle?
there is no gap to insert a pry bar?
Old Jan 20, 2003 | 03:42 PM
Mikey's Avatar
Pry or tap the end of the axle with a hammer. Do what's necessary!
Old Jan 20, 2003 | 06:43 PM
myhatchrips's Avatar
ok heres the easiest way. take the whole intermediate shaft off with the axle. now get a bar and lie it flat in between the half shaft and the intermediate shaft. make sure the bar does fit in between rather almost but not just quite. now tap it with a hammer once and its out.
Old Jan 20, 2003 | 08:48 PM
HT's Biggest Loser
Default Re: Removing axle from intermediate shaft? (myhatchrips)
No No No, You call that the Easiest way?? theres No need to take the intermediate shaft off whatsoever, the axle should pop out of the intermediate shaft relatively easy with the assistance of a prybar, do that, its your easiest method..trust me
Old Jan 20, 2003 | 08:55 PM
Nameless RB26's Avatar
If you're dropping the tranny, I'd suggest taking off the shaft to prevent the tranny from getting hung on it.
Just a precaution, because I broke my ITR LSD being hung up on the midshaft..
Old Jan 20, 2003 | 09:02 PM
b19coupe's Avatar
If you just want to remove the axle, once the axle is free of the hub, use a hammer and a brass drift to pop the axle off of the intermediate shaft. Place the brass drift on the inner c.v. joint along the outer rim.
Old Jan 20, 2003 | 09:24 PM
PhatOptimo's Avatar
Get some leverage and pry in-between the inner joint and the i-shaft. Once it pops out an inch or 2 it will pull out easily.
Old Jan 21, 2003 | 02:09 AM
-CP-'s Avatar
Default Re: Removing axle from intermediate shaft? (Phat_Optimo)
ok i tried hitting it with a hammer
but i couldnt seem to get the whole head of the hammer 2 make contact, still no budge,i tired using a pry bar but there is no gap to insert it into
should i just keep hitting with hammer?
Old Jan 21, 2003 | 05:44 AM
whitelightning's Avatar
prybar buddy!!!!worked for me good luck
Old Jan 21, 2003 | 08:07 AM
Mikey's Avatar
Do what b19coupe said and use a brass drift as an aid... I know you most likely don't own one so don't bother going out and buying one. If you need to take off the intermediate shaft to get off the axle, DO SO. It's not that hard to get that off and back on.
[Modified by Mikey, 11:09 AM 1/21/2003]
Fa5_si92
Honda Civic (2006 - 2015)
Sep 2, 2018 07:07 AM
ExpeditiousRacing
Honda CR-V & Element
Feb 25, 2011 02:28 PM
MUGEN_EG95
Jun 17, 2009 03:42 PM
jansenrw
Jun 29, 2003 07:29 AM
robbin
May 14, 2003 06:17 PM
