oil leak
i dont know where its coming from but i have oil on the head and tranny its on the passenger side, i thought it was the vtec solenoid i took it off and checked the gasket and its fine, i even put a lil honda bond just to be sure. sealed it up and cleaned it all up, well 1 week later there is more oil than before, i thought the valve cover gasket but there isnt any oil marks coming from it, is there any oil related hoses by the distributor for me to check? im baffled, i thought about cleaning it all up checking the torque specs on the valve cover and honda bonding the outside of the vtec solenoid anything else i can check.
ttt
there is oil all over the ******* place, alot of oil, and the valve cover gasket is fine, it cant be the cam seals, the cams seals are on the right side of the car, the leaks on the passenger side. it looks like its coming off somewhere by the distributor but i checked that too and its not dripping. any ideas, any oil lines or anything in that area.
DCAR
14
Jun 24, 2012 11:12 AM
