overheating problem
Old Jan 20, 2003 | 01:35 PM
juicedricer's Avatar
Default overheating problem
the motor overheats after about 30 mins of driving i checked the radiator and theres antifreeze in it but the resevoir is full also. no leaks anywhere either. could it be the thermostat or the temp sending unit??? the fan doesnt turn on and someone i kno said worse case senario is that its a blown head gasket is this troo. i just bought this motor and the motor is still in my freinds car that i am driving until it goes into mine. i want to make sure its all straight b4 i swap it. any insight of diagnosis will help.
thanks
Old Jan 20, 2003 | 01:56 PM
1bad-eg's Avatar
Default Re: overheating problem (juicedricer)
Definitely check to see if your thermostat is opening up.
Old Jan 20, 2003 | 04:36 PM
B18EG6's Avatar
Does it overheat when you are sitting there?
if it does, it could be the fan motor, fan relay, fan fuse, or fan switch.
Does it overheat when you drive?
if it does, its the thermostat, or a leak somewhere, or air bubbles in the coolant.
touch the radiator hoses, both lower and upper. Are they warm? Did you bleed the air out when you filled it with coolant?
Take the thermostat out (PM me if you need help) and put a string around oen end (end without the 'bulb') and the other end to a pencil. Put the pencil over a pot of water, and make sure the thermostat hangs in the water without the bulb touching the bottom of the pan.
Around...i think 190 degrees or so, the thermostat should open up and you will see the rubber seal open.
If the rubber is already open, the thremostat is stuck open. If it never opens, its (duh) stuck closed.
Sebastian
Old Jan 20, 2003 | 05:44 PM
Default Re: overheating problem (B18EG6)
thanks for the insight imma check it out actually today lol b4 i go out with the car.
Old Jan 21, 2003 | 04:55 AM
B18EG6's Avatar
Alright...lemme know what you gather
o5va1d0
Honda Civic (2001 - 2005)
Sep 5, 2011 04:30 AM
white98gs-r
Apr 5, 2009 06:51 AM
Cuda
Mar 21, 2007 11:25 PM
bigrballerz
Sep 27, 2006 12:42 PM
philosofy1
Jun 14, 2005 05:45 PM
